Panasonic Plasma TH-42PX60U - power light blinks 12 times
Have a 20 mon. old TV just turned off by iteself while it was on, i tried to turn back on and it seem to turn on and then shuts down by iteself and the i see power light blinks 12 times. Panasonic is not taking any responsibility and neither is their tech/service center, so i can use help to find out the problem and if anyone have solution.
  • 3 more comments
  • Anonymous Nov 18, 2008
    i als have the same prob. less than a year old 50 in. pansonic plasma. power light blinks 12 times.
  • Anonymous Dec 02, 2008
    I have same issue with 42' LCD
  • Anonymous Dec 15, 2008
    I have the same problem, i was only less than a month out of warranty, mine shuts off and blinks 10 times, they will not take responsibility!
  • vortechsoto Jan 17, 2009
    l have the same model TV, and the exact same problem, my TV blincks for 11xs.... any solutions, ???
  • Anonymous Mar 18, 2014
    the television turns itself off after only about 20 seconds after turning the power on
    Sniper:
  • 63 Answers
Bad capacitors...! Remove rear panel cover from tv. Most require a star screwdriver. Look for bulging caps in power supply board. (3300uf 10v ) caps need to be replaced with 3300uf 16v. Identify the bad caps.... Caps are bad when they are bulged/bulged and raised. A good Cap is flat X top not raised or buldged. I have pics of what bad caps look like on these boards. Email me if you would like to to see them. Caps cost abywhere from 1-2 dollars or you can buy them in lots of 10 or 12 on ebay for around 8 bucks. Caps need to be soldered on. Do it yourself (if confortable) or take it to a tech/pc repair shop in your local area. Do do that unplug all the wire harness from the board and unscrew the boarda nd take to your teck to solder on the new caps.
You can fix this for about 20 bucks if you have someone else solder or 40 cents if you buy the caps on ebay and replace the 2 bad ones yourself. If one is bad and the other is not replace them both.
The caps go bad because they need to be a higher voltage. 10 insn't enough..... 16 is plenty and don't go any higher than that.
Good Luck
Gunny
Posted on Feb 07, 2009
  • GySgt2u May 08, 2009
    Could be the SC or SU board. However while working on one of these I had no V on the 5V distribution from the P. Tracing Pv5 to the D alrarm panel and then on to the SS. I replaced the P nothing replaced the D nothing then replaced the SS and the set fired up.
    Could be any one of the boards. I also replaced caps on the PS.
    I have a comparable service manual if anyone is interested...
Last night we worked on a TH-50PZ700U with this exact set of symptoms. We swapped out the H and DG boards with a known good unit (mine!), to no avail. Still no power and 12 blinks. Then we swapped the D board and it worked immediately and perfectly.
I cannot tell you if this is the right revision, but here is the board we swapped.
http://www.shopjimmy.com/main-logic-d-board-tnpa3983-from-panasonic-th-58pz700u.htm
Posted on May 08, 2009
  • bastaniradme Sep 07, 2011
    I have two Tv and try to move all board but still 12 times blinking
  • Holly Hill Oct 28, 2013
    Can you explain this to me in a first timer terms as you havent explained what the actual boards you are talking about are?
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Blinking red power light on a Panasonic Viera 47 in. plasma
No sure how many blinks you have but here are the blink error codes and the common boards failures for each
Blinking Times Contents Check point
1 Panel SOSPanel
3 P+ 3.3V SOS A-Board
4 Power SOS P-Board
5 P+ 5V SOS A-Board
6 Driver SOS1SN-Board
7 Driver SOS2SN-Board
8 Driver SOS3SS-Board
9 Discharge Control A-Board
10 Sub 5V SOSA-Board
SN-Board
SS-Board
P-Board
12 Sound SOS A-Board
Speaker
13 Emergency SOS A-Board
Feb 01, 2014 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
TH-42PX60U power red light blinks 3 times
The blinking is a symptom of power supply failure
Mar 22, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
I have a Panasonic plasma TV model# TH-42PX75U --- here is a link to Panasonic web site for this model...
Unfortunately your going to have to have it serviced by an Authorized Panasonic Dealer. Independent shops will not be authorized to order parts without the consent of Panasonic. They are rough to deal with.
Dec 20, 2010 | Televison & Video
I have the same problem Panasonic Plasma TV wont come.
Alot of times capacitors on the power supply circuit board will go bad. They will bulge/dome or dry up which will cause this problem. Bad caps dont hold a charge, which is needed to maintain a voltage. The circuit board is two sided which makes replacing the caps difficult, and the board can be damaged and have to be replaced. Taking it to a repair shop may be cheeper and safer then doing it yourself. Having two-six caps replaced is a lot cheeper then a new board.
Aug 15, 2009 | Panasonic TH-42PX60U Television
Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Mar 12, 2009 | Panasonic Televison & Video
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
PANASONIC TH-42PD60U
I had a similar problem where my TH-42PX60 would turn on but all controls were disabled. I could not change channel, input, volume or anything other than turning the TV on and off. I called customer support and they directed me to this site: http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/downloads1.asp to download a firmware update onto an SD Card. I inserted the SD card into the slot in my TV and powered it on. The update took about 3 minutes and I haven't had a problem since.
This is a link to the instructions to install the update:
http://www.pasctraining.panasonic.com/specialapplications/productfirmwaredownloads/Firmware/PDP/PX60/UpdateInstructions.pdf
Nov 26, 2007 | Panasonic TH-42PX60U Television
Televison & Video Logo
2,430 people viewed this question
Top Televison & Video Experts
