Question about Alpine CDA-9805 CD Player
What is the AUX good for
I plugged the red and white plug into the back and have it set to AUX, i tried it on all three sets in the back and nothing happened, are those for output only?
Those outputs are for porting your subwoofers or speakers from your amp. In order to use the aux channel you must use the input beside it, with is called Ai/NET. It's what cd changers are commonly plugged into. I bought my cable from the local Car Audio shop. It goes from Ai/NET to female composite. Then I have male composite to male 3.5mm stereo jack to my ipod.
Posted on Nov 30, 2009
I use the Aux to plugin my Ipod, amke sure you have it set on. Then it acts as the plugin. it was originally there for XM radio or a tv.
Posted on Feb 01, 2009
How do I connect a sound bar to my magnivox TV
There is only one set of out jacks, the rest are in and they are usually right next to the in jacks. You are looking for a set of red and white colored plugs, some have a yellow with that would make three next to each other. The sound bar will work whenever the power is on then all you do is turn down the sound on the tv.
Dec 01, 2014 | Philips Magnavox 42MF521D/37 Television
Trying to hook up my nintendo 64 but there is no video or sound output??
External Speakers
Installation steps:
These steps work for Wii, Nintendo GameCube, Nintendo 64, and Super NES hookups.
Gently pull the yellow cable of the Stereo AV cable apart from the two Audio cables (red & white). Plug the yellow cable into the Video Input on the TV or VCR.
Locate an open set of Audio inputs (left & right) on your home stereo. Do NOT use inputs marked "Phono."
Plug the white cable into the Audio Left input on your home stereo. Plug the red cable into the Audio Right input on your home stereo.
Set the input select on the stereo system to match the label on the set of audio inputs. (For example, if you plugged the Audio cables into the AUX port, switch the stereo to AUX or "auxilliary."
Make sure the game is placed properly in the system.
Plug the controller(s) into the front of the Control Deck using the left most port for player one.
Plug the AC Adapter into the back of the system. Plug the other end into a wall outlet.
Turn the power on.
Turn on the TV or VCR and locate the input select. It's often called Input Select, AUX (auxilary), Line, Line In, Input, Source, Select, In, or EXT (external. Switch the input select to show the Nintendo game.
Note: If you are using a VCR, you will need to set the VCR's TV/VCR button to VCR. You can do this by putting a movie in the VCR, pressing play, then pressing stop.
The game image should now be displayed on the screen. You're ready to play.
Feb 10, 2011 | Nintendo 64 Console
I have a Sony Bravia KDL-46X3100 tv set which I want to connect to my Yamaha RX-V730 amplifier so that we can listen to tv programmes through the sound system. How do I connect them using RCA cables as I...
all you need is one set of the red and white rca cables.your tv should have an audio output with a red and white hole.plug in red and white wires to those holes at the back or side of your tv.plug the other end to your auxilary red and white holes at the back of the stereo....if your stereo doesnt have aux holes then you can plug into L.d.,VIDEO outputs at back of stereo.you then turn your select button,nob on your stereo to either the aux,ld or video.hope this helps
Oct 15, 2010 | Yamaha AX-596 Amplifier
Dont know how to connect dvd player and digital set top box to the same tv. set top working,dvd player not showing visuals on tv
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Mar 03, 2010 | Televison & Video
Rca jack diagrahm
Feb 17, 2010 | Sanyo DP50747 50 in. Plasma TV
Stereo hook up to my 51h84c toshiba
YES YOU CAN DO IT BY YOURSELF. IF YOU HAVE A STEREO, IT SHOULD HAVE AUX INPUT...YOU WILL NEED AUDIO CABLES, RED AND WHITE...CHECK AT THE BACK OF YOUR TV, WHICH SAYS...AUDIO OUT..PLUG THAT TWO CABLES COLOUR CODE MODE...AND THIS END YOUR CABLE GOES IN YOUR STEREO AUX INPUT...ON YOUR STEREO SWITCH TO AUX AND SAME TIME ON YOUR TV....SO YOU WILL BE ABLE TO HEAR SOUND
Oct 14, 2009 | Toshiba 51H84 51" Rear Projection...
I can't figure out how to put my pioneer deh 10 in auxiliary mode. I bought one of those audio cables to plug in the red and white jacks in the back, and connect my mp3 player, and I can't figure out how...
Sorry, but I don't think you can use the rca's for an aux-in. I bought a deh-10 new and there is nothing in the owners manual that even mentions useing the rca's for an aux-in.
Used it long enough to opperate it in the dark and nothing in the setup menues for changing those rca's from outs to ins.
Feb 19, 2009 | Pioneer DEH-1000 CD Changer
CDM 150 IPOD question
OK all you need is a 1/8 th inch stereo jack that goes out into two RCA cables RED and White (you can get this conector at any radio shack) now plug the red and white wires into the back of your gem sound unit AUX or TAPE..plug in your mp3 through headphone jack into 1/8 in plug....now turn on set switch to AUX OR TAPE DEPENDING on the one you plug into ..now play your mp3...make sure volume is up!
This should fix YA!
Dec 12, 2008 | Gem Sound CDM-150 Mixer
Using the device from the cable outlet
Not a stupid question. You should have received all the cables you need with the Leap Frog. To hook up your tv, take your transmitter and one set of a/v cables, usually red, white and yellow. Do one cable at a time. Your tv outputs should be color coded. You should have one set of three jacks completly open on the back or side of your tv, i.e. labeled component 1, component 2, aux 1, etc. First plug select one set of jacks. Plug a yellow plug into the yellow jack on your tv labeled video out. Plug the white plug into the white jack labeled audio L out. Plug the red plug into the red jack labeled audio R out. Now do the same on the transmitter but the jacks should say in. Yellow, white and red to video, audio L and audio R. Now take your receiver into the other room and do the same thing with the other tv. The cables go from the receiver out jacks to one set of jacks labeled Aux, component, etc like before. Pick a set that has all three open. Red to red, white to white, yellow to yellow. Make sure you then have the transmitter and receiver plugged in. Your remote is supposed to work from your other room. If this solved your problem please rate this as fixed. If you need more help with this just add a comment and I'll be glad to help you. Thanks.
Apr 13, 2008 | Terk LeapFrog LF30S
Aux sound problem
It sounds like you've connected to the front or rear audio RCA output.
Pioneer CD players generally don't have a direct auxiliary input like that - what you'll have to do is get a CD-RB10 adapter(it plugs into the CD changer connector on the back, and your cable would plug into that).
Feb 21, 2008 | Pioneer DEH-P6400 CD Player
Alpine CDA-9805 CD Player Logo
359 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
