Question about HP Office Equipment & Supplies
My printer will not let me print pictures from the photo tray
  • 4 Answers
Try changing the paper settings in the Printer Properties /Paper type.
Posted on Sep 24, 2008
HP photosmart 8100 will not print from photo tray of picture online, only main tray. IT WILL PRINT from photo tray when I print selected photos from a camera card, so problem is not with the tray or...
It probably don't support that function via the internet... or it may just be a setting your missing by default its not going to use the more expensive paper for internet printing although for a camera card it would because odds are your printing pictures from a Camera Card.... so in short no you didn't mess anything up its just a matter of settings or worst case put the internet photo on the camera stick and print it that way...TAA DAA
Oct 10, 2013 | HP Photosmart 8100 Series
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
Printing 4x6 on photo stock about a 50 picture job
Your printer should be serviced in a shop, The Canon spec's tell us where and what lubricant to use, and how much.
Aug 10, 2009 | Canon i9900 InkJet Photo Printer
Pictures will not print and paper will not load for printing pict
You need to push the paper through just touching the boundary of the printer paper tray
Feb 12, 2009 | HP Photosmart D7260 Printer
I cant print 6x4 pictures
make sure you have photo paper in the small tray and the tray is pushed in the whole way. The green light will come on. Load the paper with the shiny side down.
Jan 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I can print 4x6 photos but not documents from my computer
Maybe your phototray is still engaged. If the green light by the photo tray is on - then it is engaged and you cannot print documents. Lift up the clear lid of the little photo tray, pull it back towards you until it clicks in place. The light will go off. Close the tray lid.
You should be able to print documents now. Make sure the document tray below the photo tray has paper in it.
If all else fails, try Kodak's Help on-line at this site
They have an on-line survey tool to help you with your problem. Good luck.
Dec 02, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
My kodak easyshare5300 is printing black picture
If your product is still within the warranty period from KOdak then you can call them up for some step by step troubleshooting to help you with your problem and as well they can replace the printer if defective.
Try this first
Calibrate your printer, then print a demo sheet.
  1. If paper is in the photo paper tray, remove it.
  2. Load photo paper into the photo tray.
    1. Fan the paper to keep the sheets from sticking together. IMPORTANT: Do not overload the photo tray.
    2. Load a maximum of 20 sheets into the photo tray, with the Kodak logo facing up.
  3. Calibrate your printer.
    1. Press Menu.
    2. Select Calibrate Printer, then press Start.
    3. Wait for your printer to print the calibration sheet.
    4. Place the calibration sheet face down on the scanner glass.
      • For the 5300 AiO printer, place the sheet on the front right corner of the scanner glass.
      • For the 5500 AiO printer, place the sheet on the left rear corner of the scanner glass.
    5. Press Start.
    6. Wait until "Calibration complete. Remove calibration page from scanner glass. Press OK to continue." appears on the LCD display.
    7. Remove the calibration sheet from the scanner glass, then press OK.
  4. Print a demo sheet.
    1. Disengage the photo tray by sliding it towards you until it stops. When the photo tray is disengaged, the main tray is active.
    2. Select Print Demo Page, then press Start.
    3. Wait for the demo sheet to print.
Then call them if issue Persist at these numbers:
In the U.S. and Canada: 1-800-421-6699
In Australia and New Zealand: 1800 793 895
Thanks for using Fixya!
Jun 21, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Will not go to photo tray to print 4X6 picture
This is why Mac's are EVIL!!!! LOL, anyway try using the software, that comes with the printer, and tell it which paper type, and tray to use. Also try printing on a PC, and see if it works then, as you may have to live with this as the solution.
Feb 22, 2008 | HP Photosmart 3210 All-In-One InkJet...
171 people viewed this question
Ben Johnson
