Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Code 10 on drivers
Yellow exclamation in device manager for this device. When I try to install drivers, I get a Code 10. This device cannot start. Please help
  • Anonymous Oct 02, 2008
    I have removed the driver and reinstalled in and still I get the Code 10 error. Please help.
  • Anonymous Oct 05, 2008
    Same problem and the green light on the unit stays lit.
Same my maxtor 3200, but mine work just by wait, plug the adaptor to a wall outlet and connect it to the hard disk, do not connect it yet to the usb, wait for atleast 1hr until it is warmed up and try to touch it you will feel the the motor is running, the plug it in the usb. good luck.
Posted on Oct 18, 2008
Please post if you found an answer for code 10.
Posted on Oct 02, 2008
Lexmark x422, code 10
code 10 is a driver issue
Make sure all Power an Data leads connecting to your printer have dust free secure seating. You might have to uninstall the printer restart your computer then reinstall your printer. Click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click to update driver. Hope this helps.
Dec 24, 2012 | Computers & Internet
No Audio Output Device Installed
If you have visited the Toshiba website and downloaded and installed the latest drivers from there, then I would suggest that the on board Audio controller is defective and should be replaced. Check your guarantee and see if it can be returned to dealer/maker for repair.
Dec 16, 2012 | Toshiba Satellite L505DES5025 Notebook
When install realtek AC97 Audio, then have a message from my pc "this device cannot start (code 10)" what I can do about that, thanks in advance!
(CODE 10) no drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
hope this helps you
Oct 10, 2011 | EPoX EP-8RDA3I Motherboard
Speedstream 4100, can't download internet service cause pc there isn't any modem. The driver Intel R 82562V 10/100 network connection is missing and when i try to download it i can't get it. ...
make sure your its enabled in your bios
during the boot process you will see on your screeen to press acertain key to enter set up press and hold that key to enter set up
using arrow keys navigate to intergrated peripherals press enter look for SiS 10/00 press enter make sure ethernet its enabled
press f10 save to cmos
restrart your computer
if this fails to fix the problem
the driver for this modem should be on the motherboard disk or the disk provided by you ISP internet service supplier
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or
you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
also
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
http://download.cnet.com/intel-r-82562v-10/3000-2110_4-99324.html
http://download.cnet.com/intel-r-82562v-10/3000-2110_4-99289.html
hope this helps you
Oct 10, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
I have CODE 10 on my Realtek PCIE GBA Family controller
code 10 no driver has been intalled for this device
if this is for an internet connection
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled or you could click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device if you computer came with a motherboard disk the driver could be on it
the drivers might be installed properly for this device
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
http://download.cnet.com/realtek-rtl8139-810x-family/3000-2112_4-82823.html
http://download.cnet.com/realtek-rtl8139-810x-family/3000-2112_4-96337.html
if these driver packages aren
Sep 15, 2011 | Computers & Internet
This device cannot start. (Code 10) Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available. I get this code when I look at the...
code 10 no drivers installed
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you need more help with this post a reply
hope this helps you
Aug 15, 2011 | A D S Computers & Internet
Code 10
hope this helps
Jul 30, 2011 | ASUS 5188-4214 TV Input
Fast ethernet LAN drivers not installed and gives error code 10
Go to setting,control panel,system,device manage then click the network adapter,then properties,in resources uncheck the box "use automatic settings" then click the change setting then "edit input/output range" and try using other value with no conflicting device then click ok.Then go back to device manager and check if the yellow exclamation point is still there
Apr 18, 2009 | Computers & Internet
After installing vista service pack 1 my dvd rom is gone.
Download the latest driver for dvd rom from Acer that will work with Vista SP1. Also try uninstalling the device in device manager and restart your computer. Vista may find "new hardware" and install the driver from its driver pack in SP1.
Jul 28, 2008 | Acer Aspire 5500 5570-2609 Laptop
I cant install Computer Speakers can someone help me? Computer says audio device installed but not working properly. Gives error code 10. What does code 10 mean?
Code 10 means that the sound card drivers could not start.... try this:
Goto START.
Right click on My Computer and select properties.
Select the hardware tab.
Select Device Manager.
Here you should see the audio device with a yellow exclamation mark by it.
Right click on it and select uninstall.
Once that has happened look for ACTION in device manager ( Up by FILE and select scan for new hardware.
IF this doesn't fix it you'll probably need to try downloading the latest drivers for the card or it could be defective!
Apr 27, 2008 | Audio Players & Recorders
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
188 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
