Question about Sony STR-DE525
Sony STR-DE525 Protector mode
Howdy, I have a Sony STR-DE525 that faults to protector mode when turned on. I have located a2 blown output transistors and a burnt resistor (R527). The resitor is too discolored to get a code but reads 7.1K with a meter. Can anyone confirm this is the correct value? I would also appreciate any tips as to other components to check before ordering replacement parts. Any and all help is greatly appreciated.
Thanks, Gary
  • 1 more comment
  • Gary Woodruff Sep 25, 2008
    Howdy, thanks for the link to the print. I have the value of the resistor now. I have checked the two lg caps and all output transistors. Could anyone point me to any other components to check before ordering parts.
    I was trained as an electronic but have not worked in the field for many years. I have all of the necessary equipment and skills. I am just looking for someone with experience repairing this problem with the Sony STR-DE525 as it seems to be a frequent repair.
    Thanks, Gary
    I have two blown transistors and one burnt resistor (Q506, Q507, R527) . I do not see any other components bad that are in the vicinity of these parts. Amp board is $116.00 + shipping, transistors are 4.25 each. I would rather order just what is needed and save $100.00 (if possible).
    Thanks, Gary
  • 10,594 Answers
Download service manual of STR-DE525 here and fix your receiver.
Must download all 4 files at web site.
Need further help, let me know.
Posted on Sep 24, 2008
Testimonial: "Thank you for the print. amp is back in working order!"
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Sep 25, 2008
    To repair an Amp or receiver is like step by step job for amature. Order new parts, replaced them and check result.
    How about rating solution?
    Alright, let me know your finding of bad components with circuit codes like Rxx, Cxx and Qxx etc.
    Just a suggestion, why dont you replace Amp Board completely?
Dh520 protect mode
Usually means you have a blown amp channel. Shorted output transistors and burnt resistors.
Oct 06, 2014 | Sony STR-DH520 A/V Receiver
Receiver protect
You mos likely have a problem in the amp section that is causing the unit to go into protect. Probably shorted output transistors and some burnt resistors.
Aug 16, 2013 | Sony STR-DE525
The protector flashes STR DE625
Chances are it will need replacement parts (output transistors and a couple of resistors) Probably best left up to a repair shop tech.
Feb 01, 2010 | Sony STR-DE625
Protector mode
try resoldering all open circuits then on power supply section check the electrolytic. capacitors. which are 80 volts, 10000microfarads also check regulators which 5&12volts (la7805&la7812) and I suppose things will workout
Nov 16, 2009 | Sony STR-DE525
Flashing protector
This usually means an output transistor is shorted and the amp is protecting itself. There are usually 2 8 amp fuses GMA type (glass tube) that are located near the large transformer on the main board that also get blown. You can try the fuses and see if it fixes it (10% of the time it will). If they blow again, it will be one or more output transistors are shorted, and the unit will need professional repair.
Jun 13, 2009 | Sony STR-DE435 Receiver
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
SONY STR DE525
nothing is connected at this time no speakers or in puts.....
posible component failure???? any common check points..this thing is pretty webbed with them
Jun 16, 2008 | Sony STR-DE525
When power on it only shows protector and it doesn't work
The output transistors are probably defective. These are MN and MP transistors available from Sony and run about $12 each. There may be other components in the output stage that need to be replaced as well. Expect about $25-$40 in parts plus the local labor rate.
Dan
Mar 26, 2008 | Sony STR-DE525
Sony STR-DE525 Logo
1,750 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
