Question about Kenmore 44102 Front Load Washer
Bearing failure machine drum loose.have removed pulley ball bearings missing in race.how do you get the drum out for repair and what parts are required as not shown on parts list.
  • 32 Answers
You have to pull entire tub assy out of mach,removing all hoses,motor,wiring shocks and springs.then you remove all the bolts going around the middle of front and rear tub.the bearings and seals are pressed into the rear tub and are not removable for separate replacement.rear tub and basket have to be replaced together and is quite expensive to buy these parts..good luck
Posted on Sep 29, 2008
Repair manual for 7kg eco wash system ewf1074?
Replacing the bearings is a comprehensive job and requires expertise and a lot of time.
First of all should estimate which parts should be replaced.
These are certainly the following parts: "Ball bearing - 25x52x15",
"Ball bearing - 30x62x16", Seal of drum shaft - 35-62 and besides them should be reviewed the state of drum shaft.
After a thorough review, you should estimate whether the repair cost or cheaper to buy a new washing machine.
First of all, I recommend that you look the tutorials on the following links:
How to Replace Washing Machine Bearings
http://www.how-to-repair.com/help/how-to-change-bearings-on-a-washing-machine-2-of-4
Dado
May 03, 2015 | Electrolux Washing Machines
Spin Cycle is very loud on front load washing machine
See here
How to fit a Bearing in a Washing Machine | Appliance Repair Help
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
From
DIY washing machine repairs (2)
for repairs check
Sep 04, 2008 | Washing Machines
Replace beko 8227 drum bearings
Remove drium.
Remove bearing(s) from drum
Using a brass drift punch find the two slots behind the bearing race,
and drive the race out using the brass drift. If you must use a steel drift , wear eye protection as the race may shatter like glass.
Install new race, purchased for an auto parts dealer or a bearing dealer, if one is available to you, using the brass drift punch, or a piece of wood and a hammer . Do not allow the hammer to touch the new race.
Pack the new bearing(s) with grease. Reassemble drum onto machine.
Jan 14, 2015 | Beko Washing Machines
How do I stop dryer from squealing
the squealing noise is most likely a loose drive belt , the drum is powered by a large belt to a motor , the belt and idler pulley are most likeslyin need of replacement
Dec 11, 2014 | Dryers
The basket inside the washers seems loose
Ball bearing housing got damaged or the drum shaft that holds ball bearing center race is worn!
Apr 06, 2010 | GE WCVH6260FWW
Dryer make a squeeling noise when going, how do I fix and get the back off the dryer
Nothing could be easier to work on than these beautys. After unplugging the machine start by popping the top so you can get to the screws holding the front panel on. As pictured gently push the springclips in on each side about 2 or 3 inchs from each end to release the top: top%20removal.jpg Pop that top with a putty knife. After removing the 2 phillips screws holding the front to the frame (near the top on each side) and taking the wires loose from the door switch, lift the front panel out yer way.
Remove the rear hatch and take the idler loose. Then you can get the drum out. Grab the belt and yank upwards on the drum and remove it out the front.
INSPECTING THE DRYER Look for broken glides on the front panel: 5303937139.jpg?height=147&width=200 5303937139 glide kit $24 The rear drum has a big trailer ball type mount that holds it into place, over time the plastic bearing wears out and the support under it squeals, (it is telling you serious stuff is going to happen) The metal mount under the by now thin, failed, and gone bye-bye plastic bearing, will eat into the ball and cut it off causing the drum to fall into the heater element AND break the belt. YIKES! NOT GOOD! a%20frigidaire%20dryer%20bearing%20failure.jpg?height=150&width=200
Failed bearing with missing ball
The kit (5303281153) comes with everything you need to repair the bearing. It is about $25 bucks or less. With the drum removed and the bearing inspected you want to take a gander at the heating element. If the element is broken, there is no need to buy the whole pan for $100. You can get a restring kit for about $25. Just remember to evenly space the new wire so it will not burn out quickly. Remove all lint from the dryer and the drum. This is the main killer of a heater element. Lint on it causes a hot spot. gibsonfrig%20elec%20coil.jpg 5300622032 Restring kit $25 The fuse mounts on the rear wall of the dryer in the upper right hand corner. If it blows the dryer will not run. Clean out the vent and any lint in the dryer or the fuse will continue to blow. gibson%20rear%20wall.jpg 134120900 Fuse $12 The belt part # is 5303281154 $10 The Idler is part # 131863007 $12 For routing info see Belt routing above on anotha page my friend. LOL Or better yet how about the repair manual? Here is a newer repair manual. The innards of the dryer is the same as always but the newer models have a thermister and assorted goodies: ELECTROLUX REPAIR MANUAL
Oct 24, 2009 | Frigidaire FDE336RE Dryer
Maytag EpicZ Washing machine; basket drive pulley noise & wobbly
sounds like a bad bearing...here is how I check them open the door .lift up on the tub if any play in the upwared monment it's bad...you can also remove belt and pulley spin the tub if you still hear the noise it's bad....
if bad you will have to replace rear outer tub and spinner (it has the shaft on it)
also Give Maytag a call at customer relatiions...make a lot of noise they may just give you the repair..
Sep 21, 2009 | Maytag EPICz 3.7 cu. ft. Washer
Making a loud humming noise and won't start or drain (front loading)
loud humming noise in the washers!I there may be two probable causes:
1.) pulley is loose on the shaft
2.)bearing is bust and the whole back part of the tub needs replaced because it was built integrated into the plastic tub casing.
Rust and leak streaks are signs of end-term bearing failure; the absense of these is not a conclusive indication that the bearing is unimpaired.
Remove the belt from the drum pulley and spin the drum by hand. If you hear noise, that's the bearing. hope this helps
Jul 04, 2009 | Frigidaire Washing Machines
Candy drum bearing replacement
Hello
This is fairly straightforward but little hard work to remove and fix. If you have Candy Washing machine such as model CE430 which is fully automatic electro-mechanical with AC motor , the replacement will be as follows that I have done successfully
1. Remove the belt and motor, then remove the hex nut on then drum pulley. But pulley may not come out. It is suggested to remove the hex nut whiled drum on the frame because it is easy to remove while it is on the frame.
2. Take the complete drum assembly out of the washing machine frame.
3. Leave the drum assy on a bench with pulley side upward, use puncher to tap onto the center of the drum spindle, make sure that you will not damage the screw threads on the spindle. the spindle should go down the pulley should pop up.
4. Then keep punching until drum spindle and the “Y” arm assemble comes out.
5. Now you will have the pulley and drum and Y spindle removed. the 2 bearings and water seal still in the drum casing.
6. Use rust cleaner chemical or spray to dissolve the rust off. Then use either bearing puller or use iron puncher to tap on the bearing gently but hard , may use 1kg hammer and take each bearing out. The inner bearing will come out with the water seal.
7. How to get the spare parts; these parts are very common in this geographical region ( Asia). You can buy generic parts. Get the mechanical specifications on the bearing to buy the bearing. The water seal which is generally referred as oil seal, look for specifications such as specs will have inner & outer diameter and the height ( width) ie 22 mm, 40mm and 10mm for water seal of the Candy CE430. Make sure you have the exact shape of the water seal as the original one.
8. Install back the new parts: you need to smoothen the spindle and clean the area as well. to have less friction , smoothen the spindle surface using sand-paper, it will be easy to press the bearing and the spindles.
9. 1st you install the bearings. You need to add thick lubricant in between the inner bearing and inside of the water seal. Then insert the water seal as well.
10. The drum spindle can be inserted to the bearing, you cannot use iron hammer because it will dent the drum, you need to push and may use wooden plank warp with thick cloth like towel to batter on to the center of the drum gently, if the spindle is smoothen properly it should go in with out a hassle. Make sure that drum rotates freely, then pulley can be installed.
11. The drum bearing replacement is completed
12. Re-install the other parts back.
Pub
Jun 12, 2008 | Candy AQW130 Front Load Washer / Dryer
Stainless steel drum loose
A loose inner drum usually indicates a failed rear tub bearing. The only solution is to replace the rear half of the tub. (which contains the bearing).... You can check if the pulley nut has come loose by removing the rear panel. There is a large nut that retains the belt pulley to the shaft of the basket.
Jun 04, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 44102 Front Load Washer Logo
127 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
