Question about Dishwashers
How to get the dishwasher working once it is plumbed in
  • 706 Answers
Hello debbiemiff,
Not sure I understand your question but if you are asking how to get your dishwasher working after it has been plumbed in then here are a few suggestions.. if it is a new dishwasher.. make sure you remove all the packing tape inside that holds the dish trays and wash arms from moving during shipment.. Then buy the proper detergent and do NOT use detergent that is not intended for a dishwasher ... then make sure power is hooked up .. and select a cycle and run it.. If I have not answered your question, please rephrase it so I can help you...
Regards
Posted on Sep 25, 2008
Water flows out of garbage disposal vent when ever we use the dishwasher
Most likely the whole thing needs to be taken apart and cleaned, not just the disposal, but the plumbing as well.
I have often had to do this for others.
Very often the problem has been people put things in the disposal that plug up the plumbing, like eggshells, bananana peels, and other fruits & vegetables that readily plug the system.
I have had to take such apart too many times to count.
Oh, yes.
If your dishwasher empties into the disposal ( that is normal) you may find your 2 choices are to repair or replace the disposal, or remove the disposal all together and hook the dishwasher drain directly to the plumbing.
God bless your efforts.
Jul 04, 2017 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Float not working?
the drain hose has to have a loop 18" higher than the bottom of your dishwasher right where the hose connects to your plumbing, you just have to zip tie it to a water line or drain. it needs this for that reason and also to keep your pump primed. hope this helps
Mar 30, 2010 | Bosch 24 in. SGS43C12 Classixx...
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Plumbing issues for under the counter frigidaire mini dishwasher
Your right the one with the rounded end and nut is the intake. It is supposed to be attatched to your faucet. Adapters may be needed. The other is the drain hose, make sure it is attatched firmly, you can't just throw it in sink or BIG mess will follow!
Dec 28, 2009 | Frigidaire 18 in. FDR252RB Built-in...
Once the "start" is pressed, the "reset" option on the same button will not turn it off. This dishwasher is in a new place we're buying, and we're not ready to run a whole cycle to see if the machine works...
just un-plug it for now,....then of coarse when you can run it plug it back in for test,....ya never know, just un-plugging it could very well reset itself and work fine. this is the way with alot of the newer things,....good luck
Nov 03, 2009 | GE GLD5800L Dishwasher
HI Dear water from dishwasher is leaking from
there is a cloged line between the air gap and the disposal (if you have one) or the drain under the sink.
you will need to remove the pipe and flush out with water. this is usually a rubber hose. most of the time, the clog is at the disposal where the rubber hose connects.
you should be able to see the clog once you remove the rubber hose. clean this out ( I use popsickle sticks) once cleaned out, reinstall the hose and try your dishwasher.
Oct 22, 2009 | Mountain Plumbing AG600S Air Gap for...
Kenmore Dishwasher won't fill
Not likely an air lock. When plumbing work is done the pipes ge shook up and then particles plug up the screens on these and washer and faucets. I would make sure the over flow float is properly working and then check the screen on the fill valve. Could be a coincidence and the valve failed but that is my last choice in this case. Eric
Sep 15, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
I have a neff dishwasher that is maybe 5 years old. im pretty sure there is nothing wrong with it as it was working perfectly fine before i had a plumbing problem a few days ago. after the plumbing problem...
Look for the connection from the valve to the inlet of diswasher. Check the hot water valve to be on. It is probably closed when anyone working on the plumping. Good luck.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
587 Doesn't work well
AS ABOVE SUGESTION ...PROBUBLY NOT GETTING ENOUGH WATER. NOT LIKELY THE FAULT OF THE DISHWASHER PROBUBLY SEDIMENT FROM THE WATER PLUGED THE INLET SCREEN OF THE FILL VALVE. MANY TIMES THE MOVING OF A FLEXIBLE PLUMBING LINE BRAKES LOOSE ANY SEDIMENT AND DEPOSIT DURING THE INSTALATION OF A NEW DISHWASHER WHICH IS WHY MOST ADVISE REPACING THIS SMALL FLEXIBLE LINE WHEN INSTALLING A NEW DISHWASHER. YOU WILL HAVE TO DIS ASSEMBLE VALVE TO CLEAN SCREEN ...IF YOU BOUGHT THE PROTECTION AGREEMENT OR HAD SEARS INSTALL IT THEY SHOULD COVER A SERVICE CALL TO CLEAN THE VALVE.
Jan 24, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
103 people viewed this question
Top Dishwashers Experts
