Question about HP Compaq Presario V6000T Notebook PC
Lights blinkng w/power
When I turn the power on the blue lights come on as usual but then they go off, the screen never comes on. Please help me
  • 1 more comment
  • GATOR13 Dec 22, 2008
    the same exact thing used the notebook the night before shut it down next day powered up lights came on nothing happened then lights started blinking
  • Andy Caldwell Apr 18, 2009
    It is a motherboard problem. You need to replace motherboard! Mine is doing the same thing.
  • Terry L. Freeman
    Terry L. Freeman May 11, 2010
    With the information you have here, this sounds like a memory module problem. Give me more details, but try what I have here.
    If this is a new desktop or laptop, take it back to have the techs check the memory to see if the memory modules are seated properly or could be damaged/bad batch.
    Problem Solver:
  • 3 Answers
It is a bad mother board. Mine did the same thing. If you continue hitting the power button it will eventually come on but you will have the same problem the next time you turn it off.
Posted on Apr 18, 2009
Toshiba Satellite C850-13E both power lights flashing
verify that you are using a tobisha power adapter that is for this computer. blinkng light are normal associate with wrong voltages
Apr 21, 2014 | Toshiba Satellite C850-13E 15.6-Inch...
Black Screen
It sounds as if the lamp has failed possibly due to a failed cooling fan (the fan should be the first thing to come on). here are the links to the user manual if you need it; http://merchant.satisfusion.com/sf/library/manuals/owners/50_55_60VG825.pdf and http://merchant.satisfusion.com/sf/library/manuals/owners/50_55_60VG825_Part2.pdf It may be worth trying to uninstall and reinstall the lamp, but usually these fail internally rather than having bad connections etc. It is often obvious when the lamp has gone from a visual inspection. If the lamp has failed, when you replace it, make sure the fan comes on - if not then turn off instantly and investigate further. One other possibility before buying a new lamp, is that the lamp compartment cover may not be properly fitted. This will interrupt the power, so I am assuming there is a microswitch or similar that the cover or the screws that hold it should contact. Possibility is that the cover is badly fitted, or a small piece of the cover has broken, which would normally contact the switch, or the switch is faulty - if you can see the switch then a continuity meter will easily test the switch. Also check that the lamp unit securing screws are properly tightened, they also may stop the TV powering on. Please ask again if you need more help with this, if you are unsure then a photo of the inside of the lamp compartment and the lamp itself may help :)
Jun 26, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Dual XDMA7650 all wire hooked up, unit will turn blue but the display wont light up. Tried holding the power button nothing. Please help me I am so frustrated!!
i have this same issue it lights up blue and plays music ...the inner screen lights up and what not but the outer screen will not light up at all helpppppppp
Mar 04, 2013 | Dual XDMA7650 In-Dash CD/MP3/WMA Car...
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Sep 27, 2012 | Protron PLTV-32 Television
Was on the internet watching movies, I paused the movie and went to cook. When I returned, the screen was completely blue and wouldnt come out of it. I manually shut down and tried to reboot. My system...
my suggestion to you is that you try connecting to an external monitor and see whether it works or not then we can proceed basing on your feedback....please,let us know the outcome
Oct 28, 2010 | Dell InspironTM 1501 Notebook
My hp 9000 screen is not turning on?
Sounds like you need to check my Tips and Tricks link....
http://www.fixya.com/support/r4540660-replace_acer_laptop_lcd_screens
Hope this helps Rate me please
May 03, 2010 | HP Pavilion dv9000z Notebook
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Blank Screen
Same Problem. I fixed mine with a baseball bat, hammer, and a cold beer. Lesson learned: NEVER BUY DELPHI AGAIN. NEVER..... Tell your friends. Delphi = POS
Aug 10, 2008 | Delphi NAV200 GPS Receiver
Projection ultra vison not turning on PLEASE HELP!
quite possible the rca's system wires had come loose from connectors in the back that run the video will try this first since it was working perfect before i believes wires were some how jared loose my mom had something silmilar to your device she acidently moved it had the same problem
May 10, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
HP Compaq Presario V6000T Notebook PC Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
