Question about HP Color Laserjet 3550 Printer
Hp color laserjet 3550
ERR: 10.92.02 Cartridges are not engaged.
  • 1 more comment
  • Anonymous Nov 05, 2008
    For me one of the metal connectors had been bent out of shape. Thanks for showing me where to look though!
  • Anonymous Dec 02, 2008
    I am having this same problem as well, no matter how many times I open and close the door after the cartridges are inserted.
  • donkeypunch Dec 02, 2008
    i am not finding the loose plastic black piece that is in the slot.
    Novelist:
  • 170 Answers
If you drop down the door to the toners & remove the toners that the machine says are not engaged. Now look on the right side where the toners are suppose to slide in, more then likely with this model you will find a small black plastic piece that is loose in the slot. you may need a needle nose pliers to remove it. (these pieces are remnants of an old cartridge) once removed, pop the toners back in and whala!! Hope this helps you out and if it does, please mark as a fixya...thanks Dan
Posted on Sep 24, 2008
Error 59.99 for HP laserjet 3550
Thank you for contacting Fixya with your printer inquiry.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=411173
HP Color LaserJet 3500, 3550, and 3700 Series Printers - 59.99.00 Error Displayed on the Control Panel Issue
When faced with a 59.99 error, we have found additional ways to solve the issue since the service manual was written.
Error: 59.99.00 Description: An error occurred in the secondary transfer engaging mechanism. Solution
Follow the troubleshooting steps below:
  1. Fuser seated improperly. Reseat the fuser.
    NOTE: You may hear grinding sounds from the right, rear of the printer associated with this specific failure also.
  2. Faulty secondary transfer engagement sensor. Replace the secondary transfer engagement sensor. (PS16, part of paper pickup/feed assembly)
  3. Faulty secondary transfer engaging solenoid. Replace the secondary transfer engaging solenoid. (SL4, part of paper pickup/feed assembly)
  4. Faulty feed motor. Replace the feed motor. (M1)
  5. Faulty DC controller PCB. Replace the DC controller PCB.
  6. If the 59.99 error only occurred after removing and reinstalling the paper pickup/feed assembly, what may have happened is that the secondary transfer engaging solenoid SL4 may have become dislocated. See figure below. Verify position of tab on top of solenoid.
    Figure (See Link)
    h30499.www3.hp.com/hpeb/attachments/hpeb/bsc-413/.../1/343540.em
    Parts associated with this fix:
    Pickup/Feed Assm - RM1-0765-070CN).(Includes solenoid & sensor)
    DC Controller PCB (RM1-0510-000) DC Controller, CLJ 3500/3550
    Primary Transfer Roller Engaging Motor (M-5) RK2-0139
    Drum Motor (M-3) RM1-0733Drum motor - Provides power to turn cartridge drums
    Delivery Motor (M-2) RK2-0138
    Feed Motor (M-1) - RK2-0137 Located on lower left front of main right side plate assembly
    Secondary transfer engagement sensor. (PS-10) (Part of Pickup/Feed Assembly)
    Secondary transfer engaging solenoid. (SL-4) RK2-0145-000CN
    Formatter Assembly Q1319-67903
    Parts sources:
    http://lbrty.com/Products/HP/parts_hp/pnC3500.html (Very Good Parts Vender Catalog) http://www.feedroller.com/Store/clj3500.php (Parts Vender) http://www.laserprinterservices.com/hp3500/hp3500.html (Parts Vender) HP Customer: To order HP computer parts and printer parts by phone please call 1-800-227-8164 , Monday-Friday, 7:00am to 7:00pm CST.
    Thank you for using FixYa. Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 16, 2011 | HP Color Laserjet 3550 Printer
Hi person incharge, Printer shown error 59.99 Model : HP Color LaserJet 3550
59.99 An error occurred in the secondary transfer engaging mechanism. following four possibilities are mention below with proposed action:-
1. Faulty secondary transfer engagement sensor. Replace the secondary transfer engagement sensor.
2. Faulty secondary transfer engaging solenoid. Replace the secondary transfer engaging solenoid.
3. Faulty feed motor. Replace the feed motor.
4. Faulty DC controller PCB Action: Replace the DC controller PCB.
Good Luck
do Rate if got gelp
Dec 01, 2010 | HP Color Laserjet 3550 Printer
Hp a color 3550 error 5999
Hello Dear ,
Pls do as i define to you.
This will come due to secondery transfer eng mechanism
It may be due to sec transfer engagement sensor replace/clean them.
May be secondery transfer eng solenoid replace them
May be feed motor will be faulty
May be DC controller card faulty
First check step by step it may be solve in first two steps.
Sep 25, 2010 | HP LaserJet 3550 Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
My HP Color Laserjet 3550 Printer wont print black when it is out of color ink
go through the menu on the printer ,there is a setting where it can be set to continue printing when the toner is out.
Mar 19, 2010 | HP Color Laserjet 3550 Printer
Hp color laserjet 3550 59.99 printer error
This error shows
Action: Replace the secondary transfer engagement sensor.
Action: Replace the secondary transfer engaging solenoid.
Action: Replace the feed motor.
Nov 09, 2009 | HP Color LaserJet 3500 Printer
Hp color laserjet 3550 - error message "cartridges not engaged"
here are the codes for the error you are getting
10.92.00 Black toner
10.92.01 Cyan
10.92.02 Magenta
10.92.03 Yellow
The fix is either the toner lock is broken. Contacts on the left side of printer are damaged.
There is a complete proceedure for replacing the the toner locks which comes in a kit you can order from precisionroller.com. this takes about an hour.
If the contacts are damaged you will have to replace the whole plastic part on the left side behind all of the electronics. It takes about an hour
Jun 14, 2009 | HP Color LaserJet 3500 Printer
HP Laserjet 3550 Fuser Jam Error 13.20 Had it in
You need to ask them to change the fuser..The fuser is the part of the printer that actually melts the toner onto the page. Here is a website that gives you more info on the fuser so they can't B.S. you anymore..either the fuser works or it doesn't..
http://www.theofficeguide.com/toner-cartridges/faq2.html
Please rate this solution thanks.
Mar 25, 2009 | HP Color Laserjet 3550 Printer
install the latest version of dirvers from www.hp.com, and change the settings where paper source is automatic. that all problem solves. feel free to mail me
Jan 15, 2007 | HP Color Laserjet 3550 Printer
597 people viewed this question
Ben Johnson
