Question about IBM 4232 Matrix Printer
Error Code FE6
Does this require a firmware upgrade?
  • 65 Answers
It could be that the printer simply needs to be unplugged and powered off for 10-15 seconds then rebooted. If that error comes back then its quite possible the print board is bad.
FE6 PRINTER BOARD FAILURE
SEE USER'S GUIDE
Posted on Jan 17, 2009
My burner stopped burning cd's in iTunes and Windows Media Player.
This may either be due to the software you are using or to the hardware. Start with upgrading your burner's driver. If this does not help, try upgrading the firmware of the burner. If the firmware upgrade procedure fails, it gives you an error code. Look up for this error code on the internet.
Oct 25, 2013 | ASUS K53E-BD4TD 15.6in Laptop i5 2.4GHz...
How to upgrade my firmware for bd520
One is to click the "Upgrade firmware" link on the admin page. Download the firmware image to the machine your browser runs on, fill in the field that says "Please select a file to upgrade:", click the Upgrade button, and have the right thing happen. This is the least error-prone procedure and is recommended.
Another way you can use firmware-upgrade floppy images from their website. This requires that you boot Windows or use WINE. Not recommended.
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Mar 10, 2013 | Computers & Internet
Error code 3508 after installing a new cartridge
As Kodak suggests in these cases - upgrade the firmware for your printer.
  1. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
    2. Follow the instructions to install the firmware.
If the error continues, try to contact Kodak
Oct 03, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
I have code error 6202
To resolve this error:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
When the printer is ready (no error message), upgrade the firmware for your printer: the firmware for your printer.
Install the firmware from the products site.
If the error continues and you cannot upgrade the firmware, contact the product company.
Hope this help.
If u find this solution please rate me.
Jun 11, 2011 | Office Equipment & Supplies
Error code 46
The error message "Print Unable 46" is an indication that the machines ink absorbers are almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
There is a possibility that this message may have occurred in error. Upgrading the firmware of the Brother machine may resolve the issue. Follow the procedure below to determine if a firmware update is required:
-if the display screen is displaying an error message, press the STOP/EXIT key to change the LCD to the main screen.
-press the # and * key at the same time. The first 2 characters on the top row will determine the ROM version.
If the ROM version is OE or greater (example: OF, OG, OH, etc), the firmware does NOT need to be upgraded. If the ROM version is OA, OB, OC or OD, follow the procedure on this link to upgrade the firmware.
If the message "Print Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center.
Dec 27, 2010 | Brother Multi-Function Center MFC-5860CN...
PANASONIC DMR EZ48V SAYS ERROR CODE E60
I think that is an error created whist attempting to record digitally. If the error is not there on analogue, a firmware upgrade may be required and that has to be carried out by downloading the firmware and uploading it through the specialist interface that most High End Panasonic Dealers will probably have.
I also think it is to do with copyright, only one copy using digital. Like recordable Minidisk has or CopyCode etc.
Hope that helps.
Dec 10, 2010 | Panasonic Televison & Video
Error code 46 -- Display indicates "Unable to clean 46"
If the message "Print Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000059/faq002659_000.html?reg=us&c=us&lang=en&prod=mfc290c_all&Cat=11
Oct 20, 2010 | Brother MFC-845CW multi-function...
Upgrade firmware of toshiba estudio 168
very possibly but you will find this very difficult because that machine requires special jigs to upgrade firmware.
Sep 04, 2009 | Toshiba Office Equipment & Supplies
Not possible actualization firmware E10
Device may require on-line firmware upgrade. Try updating firmware while connected to Internet.
Jul 15, 2009 | iRiver E10 Digital Media Player
LG error code 7777 on firmware upgrade
According to Sprint, If your phone already has the most current firmware installed it will generate this error code when you try to update it. Error code 7777 simply means there is no firmware update available. So no worries, you're good.
I got the same error and message on my LG LX370 when I tried to download the latest firmware on my new phone. I called Sprint and we tried just about everything before a supervisor confirmed that that was all the error code meant.
DK 12/04/2009
Jun 01, 2008 | Cell Phones
IBM 4232 Matrix Printer Logo
81 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
