Question about Chamberlain 950CB Remote Control
Purchaes 61LM as a scond remote, copied dipswitches but does not work.
Existing door opener and remote work fine. I purchased 61LM for second opener. Set dip switches, did not work. It is a auto programmer unit, so I tried the auto,program on the new 61LM, it worked the door ok, but then original remote would not open the door. Re check dip switches, no work.
I then set dip switches in opposite to original remote. Still can not get both remotes to work the overhead door.
Philip E Payne
pepparis@suddenlink.net
ktkodama
  • 37 Answers
SOURCE: Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Posted on Jan 20, 2009
  • 10865 Answers
SOURCE: i have a chamberlain 950-315cb
Here is the website which will provide you with all of the info you need on the chamberlain remote and door openers
http://www.liftmaster.com/consumerweb
Posted on May 19, 2009
  • 6 Answers
SOURCE: Locked out & Remote not working
There should be a green button on the back of the motor unit, press it for 2 seconds and then hold down your remote button until the light flashs. or for 3-5 seconds and then activate the remote. that might solve your problem
Posted on Jul 24, 2009
  • 20 Answers
SOURCE: universal remote does not work
Posting your garage door model would help, but there may be a button close to the LED on the garage door opener that you have to depress to allow the two to pair up. Assuming that this is the similiar to my garage door control mechanism, if you have the dip switches set correctly you need to depress the button mentioned above and then depress one of the buttons on the remote.
Posted on Aug 18, 2009
swolfinor
  • 504 Answers
SOURCE: Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
Posted on May 27, 2010
I lost my remote to my chamberlain lift master 1000 series garage door What can i do?
Look in the yellow pages for a Chamberlain dealer. They will be glad to sell you a replacement.
Dec 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
How can I reprogram an old style 61LM to a garage door with a learn button? Thanks!
This Liftmaster 61LM remote is the equivalent remote t? the Sears Craftsman 139 model number listed above. It h?? dip switches inside the battery compartment that ??? match up w?th ???r existing remote t? m?k? ?t open ???r garage door. There is also a set ?f dip switches ?n the overhead opener itself ?f ??? n? longer h??? a working remote. It ?h???? b? easy t? find ?n the garage door opener. This remote operates ?n a 390 MHZ Frequency, and works ?n models fr?m 1984-1992 essentially.
There will be a colored learn button on the motor head. Press and release this button and then press the button on the remote. That is it. Thanks BB Sorry about the lousy question marks in the last post
May 13, 2010 | liftmaster Chamberlain Garage Door Opener...
Th?? Liftmaster 61LM remote ?? th? equivalent remote tο th? Sears Craftsman 139 model number listed above. It h?? dip switches inside th? battery compartment th?t ?ου match up w?th ?ουr existing remote tο m?k? ?t open ?ουr garage door. Th?r? ?? ???ο a set οf dip switches οn th? overhead opener itself ?f ?ου nο longer h?ν? a working remote. It ?hου?? b? easy tο find οn th? garage door opener. Th?? remote operates οn a 390 MHZ Frequency, ?n? works οn models frοm 1984-1992 essentially.
Mar 21, 2010 | liftmaster Chamberlain Garage Door Opener...
I bought a house with an old (1980's) Sears garage door opener. I have two Stanley remotes that were in the house at the time of purchase. The opener works fine at the hardwired button in the garage but I...
On the remotes put switch #1 in either position and match up switches 2 through 10 to the dipswitches on the motor unit. There is a good possibility your receiver has quit working.
Mar 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can't use remote to open garage door
I had the same issue when I moved to a new place.
I was not able to find very much information on the interenet about it. Your remote has lost its sync with the garage door opener.
I called the 1-800 number located on the unit itself (yeah it took a ladder to get it) and the walked me though the setup in about 2 minutes.
I spent longer on hold than it took to setup the remote.
You need to make sure that you a clear on the model #s before you call them.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote to garage door opener wont work no solution on fixya
The Clicker is a hard one to program. You might try it a couple more times to be sure it won't work.
The 61LM is the Liftmaster remote that goes with that unit. There is a possiblity that the reciever on the board is bad. That board is no longer available but you can get a 635LM external reciever that is backward compatable with the 61LM remote.
Jan 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Mar 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 950CB Remote Control Logo
59 people viewed this question
Top Chamberlain Televison & Video Experts
Raj Patel
Are you a Chamberlain Televison and Video Expert? Answer questions, earn points and help others
