Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Mfc-240c reading offline and empty black
I have a mfc-240c. i ran out of black ink. i put a new ink cartridge in the slot. the printer asked if i replaced the cartridge, i hit #1 for yes it procceded and cleaned it. once it was done i tryed to print. the computer desk top popped up with an error displaying my color levels and status of the printer. it read empty black and printer offline. i unplugged the printer and replugged it in. same error. i went to control pannel to make sure it was set to that printer and it is. so i replaced it with another brand new black ink cartridge and the same error is still arising. customer service in india rerouted me 4 times then i was hung up on. no one seems to know anything about this printer. if any one has a solution please let me know.
powershot23@aol.com
Regarding your problem: If one of the color ink cartidges is out of ink, the MFC 240C printer will not operate when you only install a black ink cartidge. It requires that all four catridges have ink available in them for it to function. When you examine a cartridge it may appear that it has a little ink in it when you get message that the cartridges needs to be replaced because a little ink remains to prevent the print head from drying out. JLHinton1@bellsouth.net
Posted on Sep 27, 2008
My brothers mfc 240c printer wont print because one ink is not full but it has black
You need to have ink in all cartridges to print. You can put a small electrical tape over the little window on the cartridge to print with empty inks, but you risk an air bubble in the ink tubes. If you don't care about printing color at some time, just cover the window on empty carts.
Apr 20, 2010 | Brother Multi-Function Center MFC-240C...
Tip
How to change an ink cartridge on the Brother MFC-240C
The Brother MFC-240C uses an individual cartridge for each color (black, yellow, cyan, and magenta). When one of the colors is out of ink, the printer will tell you to replace the ink cartridge. To replace a cartridge, follow the steps below.
All four cartridges are located on the right front side of the printer, behind a cover. Pull the cover forward from the side, where there is a slight cutout for you to grab. When the cover falls forward, you'll see the ink cartridge holders.
For whichever ink cartridge you are replacing, push down on the purple handle for that color. The ink cartridge holder will open and fall forward, revealing the ink cartridge itself. Push down on the cartridge holder and the cartridge should pop toward you a little bit. Grasp the cartridge and remove it.
Open the new cartridge and remove it from its wrapper. Discard the yellow cover, unless you plan to use it for the old cartridge.
Insert the new cartridge into the correct slot (from left to right: black, yellow, cyan, magenta) so that the word "brother" is right-side up and located toward the top of the cartridge. Once it is most of the way in, push the ink cartridge holder up by the purple handle until it snaps into place. Then close the ink cartridge cover.
If you were out of ink, the machine should recognize the new cartridge and perform its calibration. If it doesn't automatically recognize it, it will ask if you have changed one or more of the cartridges. Press "1" for Yes.
Once you have printed a test page with all four colors to verify that everything is working, either discard the old cartridge in the trash or save it to recycle. But don't get rid of it until you are sure the new cartridge is recognized and working.
on Jun 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 490 is not recognizing off brand ink
try to remove the cartridge and put it back again after a while
Sep 25, 2009 | Brother MFC 240C All-In-One InkJet Printer
Not detecting ink cartridge - or saying empty - Brother MFC 240c
Is it an ORIGINAL BROTHER cartridge ? ?
OR
A cheaper version ? ?
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
Wont copy in black because color cartridges are empty
I'm sure you're using the Blue button to make the copy as it should do B/W copies only.
Double-check that black cartridge is not empty.
If the printer was connected to computer then we could have used diagnostics software.
So we start with a workaround.
Check if its display menu has any option of Ink cartridge level reset or something like that. If it has then do the reset.
If there is no such Menu option, the while the printer is On, open the compartment of printer cartridges and take out the 4 cartridges
and put it back.
Does any option in display Menu comes asking if cartridges are replaced? answer yes if it asks.
Now try to do a copy.
Hope this helps.
If it doesn't work then a question, how many days before the printer was last used?
May 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc 240c does not recognise new cartridges have been installed and gives message that no black cartridge and colors are near empty, new genuine cartridges have been installed.
this is what i did as a last resort after messing with this stupid printer all day and changing cartridges and getting a no cartridge message.
i took all of the ink cartridges out and took a pair of pliers and pulled out what i think must be the sensors. they are black plastic pieces toward the top part of the ink area. then i put the cartridges back in and i have been printing ever since. this was my last resort before i was prepared to throw in the towel so that was why i went at it with the pliers!
Jun 20, 2008 | Brother MFC-3240C All-In-One InkJet...
Message: "Ink empty black" --won't reset
this could be because of generic ink carts which do not have the size of the original ones. If so put some paperstrip beneath the cart to lift it up a bit.
Anyway, did you tell the printer that you have changed the cart by pressing 1? Look at the display when you insert the cart!
Feb 24, 2008 | Brother Multi-Function Center MFC-240C...
No ink display on brother mfc240c
First make sure that you are using Brother Cartridges, their machines are very sensitive to using generic ink. Put a brand new set of ink in the machine. Pull all the old cartridges out and put all new cartridges in. If this does not resolve the issue contact Brother, they are very good about helping their customers.
Jan 02, 2008 | Brother Multi-Function Center MFC-240C...
Model mfc-240c
did you replace with brother carts, are you sure machine is refering to mag and yellew being mt, not the other ones, power off, remove all carts, power on , reinsert carts one at a time answer machine when prompted. these cartridges are deemed empty even when they look like they have a little ink left. Try putting in 4 new brother inks
Nov 09, 2007 | Brother Multi-Function Center MFC-240C...
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
198 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
