Question about Nikon Cameras
I have lost my instructions and need to format my Nikon D70 compact flash card. How do I do it please?
  • 10,594 Answers
Download User Manual D70 Nikon here.
Posted on Sep 24, 2008
Can i use 4GB Compact Flash in Nikon Cool pix 4300 Nikon Digital Camera?
A 4GB CompactFlash card should work in your Nikon Coolpix, but you may only be able to use 2GB of it's space once formatted correctly. This camera formats the cards in the FAT file system. That basically means that one can only use up to 2GB of memory (2048 MB).
Check out this site for instructions:
http://www.techsupportforum.com/222-newly-formatted-4gb-compact-flash-card-out-of-memory-digital-camera/
Jul 02, 2011 | Cameras
DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Nov 02, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Please this camara rate and detials madurai nikan shor room place tell me
Hi, The Rate: Commonly the users, rate Nikon D80 in 4 - 4.5 score out 5 scale
Product detail: Nikon D80 comes to replace Nikon D70s. Memory card : flash cards. The new Nikon D80 features 10.2 megapixel DX format CCD (1.5x FOV crop), 11-area AF system (new version of Multi-CAM 1000, similar to D200), Compact body (smaller, lighter than D70/D70s), improved user interface, and 2.5? 230,000 pixel TFT LCD with 170 degree viewing angle. This camera has a removable protective cover.
For complete detail of this product you can get from this web address: http://www.nikonusa.com/pdf/manuals/noprint/D80_noprint.pdf
Nov 30, 2010 | Nikon D80 Digital Camera with 18-135mm...
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
Mar 28, 2017 | Computers & Internet
My NIKON D70 has trouble with flash cards larger than 2 G.
The D70 has known issues with certain cards / capacities. Nikon has identified the cards and capacities that are guaranteed to work with the D70 specifically, on their page dedicated to this info linked below:
http://support.nikontech.com/app/answers/detail/a_id/9601
It seems that only Lexar and Microdrive cards that are 4Gb are supported (some with significant limitations) and no card greater than 4Gb is supported at all, regardless of manufacturer.
Oct 10, 2009 | Nikon D70s Digital Camera
I have a Nikon D70. Camera doesn't read CF.
Sometimes pins inside take strain.  Read up on how to replace the CF pin unit.  Not too difficult as long as you don't force anything and remember to retrieve the little metal strip....
Sep 13, 2009 | Nikon D70s Digital Camera
Nikon d70 does not want to format
This camera allows at most a 4GB CF card, are you trying to use something larger, or does it do this with any size card? Also make sure card isnt write protected. Failing either of these suggestions, its possible that something has happened to the card slot internal to camera, they can be quite fragile.
May 11, 2008 | Nikon D70s Digital Camera
"for" message on LCD
It means you need to format your compact flash card.  Or...it may be that you've been bitten by the infamous BGLD problem (Blinking Green Light of Death) that caused my D70 to eventually be replaced by Nikon.  Thankfully it was under warranty at the point, which yours will not be.
If you haven't ever formatted your card, this is probably the problem.  To do so, just hold the two buttons that say "for" in red on them down for a second so that the letters "FOR" start to blink, then do it again while seeing that.  Let go and wait a couple of seconds.  The FOR will be replaced by numbers that tell you how many images you have left on the card until it is full.  I format my cards EVERY time I put a card back in the camera.  This prevents bad locations from cropping up on the card and creating bad images (corrupt).
Dec 27, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Camera read CF card, but cannot see on USB or other media
You can connect the camera to the computer via a USB cable and use the camera as the card reader. It will show up as a mass storage device. You should then be able to copy the images to your PC and format the card once recovered.
Sep 17, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
D70 digital camera
could be bent pin in the memory card slot
Jan 03, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Cameras Logo
103 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
