Question about Western Digital External USB 2.0 80 GB Hard Drive
Ejection Problem I installed mathcad to my external harddrive and everything runs fine but when i try to eject my external harddrive it tells me that it is in use even when im not using it. If i just pull it out then i will lose my mathcad (trust me already tried that one) Thanks for the help.
  • tinker0bell5 Sep 25, 2008
    nah that did not work... there was nothing open but my internet window and my antivirus system (neither of which is on my external harddrive)
  • 706 Answers
Just because you are not using it does not mean that your computer is not using it ctrl al and del simultaneously to get the popup task manager..then check the application tab.. if you see any processes running that originate from that external them and then select end task. then try ejecting your hard drive.. Let me know if that works for you...or if not.. I have a few other ideas that you can try... Good luck
Posted on Sep 25, 2008
My external hd (fantom titanium) doesn't regularly open on my mac suddenly
Inside the case of that Fantom is a regular harddrive.
Also inside that outer case is a small circuit board, that either the harddrive plugs directly into it; or there is an interface block the harddrive plugs into, and there are wires from it, that connect to the small circuit board.
(The USB cable is connected to the small circuit board)
It is this small circuit board that usually goes bad.
My suggestion is to remove the harddrive inside, purchase an economical external enclosure, and install the harddrive in it.
Have your harddrive back, and be able to use it as an external harddrive again also.
The Harddrive Inside:
Harddrives are measured by their Width.
A laptop harddrive is 2.5 inches across in width. (2-1/2 inches)
A desktop harddrive is 3.5 inches.
The Fantom Titanium II 500GB's harddrive inside, is 3.5 inches,
Details > Physical Spec > Form Factor > 3.5
What I can't tell you is whether it is an IDE (PATA) harddrive, or a SATA harddrive.
However this external enclosure for 3.5 inch harddrives, is for both IDE, (PATA), and SATA harddrives,
[ You can also look at the label on the harddrive, and look up it's model number online, to see if it is IDE or SATA. Just type the model number in your search bar ]
Just want to include information on IDE (PATA), and SATA, in case you are interested,
Jul 27, 2012 | Fantom Titanium II (TFD500C16) 500 GB USB...
I am running Windows XP as a virtual PC under windows 7. I find that Mathcad 11 will not install. It will install directly under windows 7 but will not run. Mathcad 11 did run just fine under XP but...
The software don,t support Win 7.See this chart form portal:
Platform Support Platform Version Supported CPU ODBC Driver Support
Windows XP Professional x64 Edition
Base OS
Intel Pentium/Xeon family with EM64T
AMD64 family
Windows XP Professional Edition
Service Release 2
Intel Celeron family
AMD Opteron family
Windows XP Home Edition
Windows 2000
Service Pack 4
Dec 20, 2010 | Mathsoft Mathcad 11 Full Version for PC
My sata external usb western digital 320 gb drive only shows up as an unknown USB device. Is there any way to get my computer to recognize it. I have a laptop using windows xp. Ive tried unplugging...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jun 25, 2010 | Western Digital 320GB MyBook External USB...
Mathcad 13 installs but won't run on Windows 7. Mathcad 14 won't install on Windows 7. Any solutions?
Run it in the compatibility mode. Right-click on the executable, choose "properties", then the "Compatibility" tab. Check "Run this program in compatibility mode for". Choose the latest version of Windows the program ran on, check the screen setting that applies for your application and click "OK". Now you can start the application!
Dec 19, 2009 | Mathsoft Mathcad 14 for Windows Full...
I upgraded my computer and reinstalled Mathcad 13 on my new computer. The installation wizard said the installation was successful but I can't get it to run. The new computer has Windows 7 operating...
My guess is that the engineers at PTC haven't figured out how make their products compatible with Windows 7! I painfully found that MathCad 14, 13, 11 do not work on Windows 7 (I have Windows 7 Pro)! They install, but the application can't even start! However, MathCad 2000 does work on this outstanding platform; I was amazed! You could use that version in the meantime, hoping that PTC will solve this problem soon! Or install Mathcad 14 on the virtual PC that works in XP mode.
Dec 07, 2009 | Mathsoft Mathcad 13 Full Version for PC
Windows 7 and Mathcad 14 compatibility
can anyone get me information whether Mathcad 14 is working on Windows 7
Thanks in advance
Nov 25, 2009 | Mathsoft Mathcad 14 for Windows Full...
Tape ejection malfunction
The problem may very well be a slipping spool idler that does not tension the tape properly when trying to eject. Try cleaning the rubber friction surfaces or replacing the part....accordianman
Feb 15, 2008 | Sylvania 2870LV VHS VCR
Wont load or eject
I have the same problem! tuner works just fine. I cant access the dvd mode. i can only access tuner, video input, and rear cam. Ive tried different cds and dvds and it did not help. Also it seems like the ejection mechenism is running continuesly.
Jan 30, 2007 | Jensen VM9410 Car DVD Player
Western Digital External USB 2.0 80 GB Hard Drive Logo
159 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
