Question about Gaggenau EB 270/271 Electric Single Oven
WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
I HAVE A WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - WHEN PLUGGED IN IT GET PF..... AFTER THE CLOCK IS SET ..
IT FLASHES ERROR CODE "F3 E0"
ANY IDEA ON THE PROBLEM...
  • scrago13 Oct 27, 2008
    Every 30 to 45 seconds, an annoying beep goes off and I get code F5E1 if the door is open and F5E0 if the door is closed. I will try the temp gadge first as it is likely the cheaper route.
  • scrago13 May 11, 2010
    Where did you find the part numbers. I have called a couple places and they can not find the part #.
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
Posted on Sep 28, 2008
Whirlpool oven Super Capacity 465 error F3E1
The F3 E1 error indicates a problem with the oven temperature sensor or a short in the oven temperature circuit. To trouble-shoot this error, unplug the oven. Check the wiring harness for damage and then reconnect it, if it is undamaged. Next check the resistance across the oven temperature sensor. The resistance should be 1080 Ohms at room temperature. Replace the sensor of the resistance is not correct. Otherwise replace the main control board.
Please add a comment with the model of your oven if you want me to look up the parts list or diagram for your appliance.
I hope this helps.
Aug 05, 2017 | Whirlpool Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
I have a whirlpool 465 super capacity stove. the top burners seem to have a mind of their own. 1 in the back doesnt come on at all and the other go to high heat even if i set them on low settings
No solution, just that you are not alone. We have had our Whirlpool super capacity 465 for 10 years, and about a year ago that large burner started to randomly go to high, even though the control is set to simmer. Ruined a few meals by not being right there watching.
Apr 21, 2011 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool Super Capacity 465 oven won't turn on
My Whirlpool Super Capacity 465 oven
Mar 15, 2010 | Ovens
Just bought a used whirpool accubake sc 465, keep getting E0-f3 error code, any ideas for a good fix?
Hello- The F3 error code indicates an open circuit in the temperature sensor. Pull back cover to access sensor wires.  At room temp the resistance should be 1000-1100ohms. If open, replace sensor. This should solve the problem. Let me know if this info helps- have more if needed. Thanks- Ed
Mar 13, 2010 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool super capacity 465 cracked ceramic element
You are looking at approx. $450.
Jan 01, 2010 | Ovens
We had a minor stovetop fire and getting the E0 F0 error code. The oven is a whirlpool gold super capacity 465.What is there to do about this?
E0 F0 is a communication failure within your control board/ eoc. If it does not reset after a 30 second power down, the board will have to be replaced
Sep 19, 2009 | Ovens
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
HOW DO YOU CLEAN SELF CLEANING OVEN SUPER CAPICITY 465
Sep 23, 2007 | Ovens
Gaggenau EB 270/271 Electric Single Oven Logo
1,939 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
