Question about Olympus Camedia D-390 Digital Camera
Write Protect and error messages
When I go to take a photo now a blue screen appears with write protect on it. . All photos on the card are now write protected and I cannot get into "play" or "Edit" in the menu to unprotect them. My camedia programme will not allow me to download them eaither. Any ideas? I have photos of my new grandchildren on there that are irreplaceable and would be grateful for any help
What should i do
Posted on Apr 20, 2009
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
Can't take photos as it says card protected. I don't know how to unprotect it?
There are 2 protection that you have to check:
1) Check on your SD Memory card that on the side there is a small switch. Move it to the opposite position and reinsert in the camera. Take a picture and see if it is OK.
2) If still appearing the message go in the PLAY menu of the camera and where there is the entry PROTECT with a Key Logo select NO.
Then it should be working fine.
Remember that then your pictures are not protected anymore.
Regards,
PDG
May 09, 2010 | Fuji FinePix S1000FD Digital Camera
Error message on screen " write protect" why is this?
Is your memory card write protected, SD cards have a small notch on the left hand side of the card which you can slide up or down to select/deselect protection.
Most cameras also have a photo protection facility in the menu to stop you over writing pictures you've decided to protect.
This can be switched on or off via the camera menu under card settings.
Apr 09, 2010 | Olympus FE-190 Digital Camera
Card protect message doesn't allow any activity with camera how to remove?
Hi there
Face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
May 25, 2009 | Toshiba PDR-4300 Digital Camera
Write protect
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - Press Ok- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Dec 28, 2008 | Olympus FE-230 Digital Camera
Locked on card protect
pp.5-6 of your manual has the information on locking/unlocking
Apr 18, 2008 | VuPoint DV-DV1-VP Camcorder
SD protection
The SD card is probably write protected, on the following link scroll down to "Optional write-protect tab" : http://en.wikipedia.org/wiki/Secure_Digital_card
Jul 15, 2007 | Polaroid PhotoMax PDC 4055 Digital Camera
Write protect
just open the card cover and press quick view and ok at the same time, and reset the camera. if that donĀ“t solve it may need to replace the mainboard
Feb 11, 2007 | Olympus Camedia C-310 Zoom Digital Camera
Olympus Camedia D-390 Digital Camera Logo
149 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
