Question about Whirlpool Dryers
Model GGW9200LW0 Gas Dryer Unit does not heat, I checked and cleaned the vent line and I also changed the fuse. Still no Heat, any suggestions?
  • 5,911 Answers
If this is indeed a GAS dryer, the next thing I would do is verify that your igniter is working. If you can see inside the dryer (under the drum where the burner assembly is), there should be an orange glow coming from the igniter after you start it. In simple theory a gas dryer works like this:
1. Press the start button, dryer drum begins to tumble, igniter begins to glow.
2. Once the igniter reaches a specific current level (as determined by the type igniter you have), the gas safety valves open and you have ignition.
Typically, the common fail item is the igniter. They simply wear out with age. I would recommend reviewing the following link to learn a little more:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for replacing an igniter on a gas range, but the type of igniter and theory of how it operates is essentially the same. It is common to have an igniter STILL glow, but not ignite, because it has become weak and will not draw enough current.
Another problem associated with no ignition are the gas coils on the burner assembly. Your dryer should have two of them. One is the pilot position coil (3 terminals), while the other is called the main coil (2 terminals). If one of these coils is defective, it is recommended that BOTH be replaced.
Searspartsdirect.com has an excellent exploded view illustration of the parts I've discussed here. Just type in your COMPLETE model number and look under the "Burner Assembly" heading. The igniter is listed as item number 4 (part #279311) and the coils are listed as items number 13 (part #694540) and 14 (part #694539).
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 24, 2008
I have a whirlpool Duet gas dryer, model ggw9200lw0. It will glow then heat up but switches off right away.
It sounds to me like your flame is not getting enough air. Make sure that ur screen is clean then clean your dryer vent. The easiest way to see if it is your dryer vent is to take the vent off the back of the dryer. If it runs good without it then you need to clean it. If the dryer heats up a couple times then wont heat up after that then you need to replace the coils
Aug 26, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Get some heat for 10 - 15 minutes and then no heat. I replaced the fuse and it worked good for a couple of weeks and now it is happening again. The new fuse was not exactly the same as the old but that...
If the thermal fuse blew you would have no heat, I would suggest to make sure you have a clean vent system to assure the dryer can breath. Simple test, disconnect vent system and run dryer, if the vent system is the cause the dryer should heat. if the fuse is blown you will not get heat. If the dryer heats at first then stops heating, I would lead you to the coil kit on top of the regulator, then can fail but allow some heat at first. Once they get warm they can fail to reopen the gas valve (regulator).
Jul 08, 2011 | Kenmore 72622 Gas Dryer
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
The dryer runs but doesnt heat up. i checked the fuses and all is well, the vent is clear and the lint screen is clean. the gas line is on
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 22, 2010 | Dryers
GGW9200LW0 whirlpol dryer runs but ther is no heat. It is 8 yrs, old. Waht to do?
heatman101
Sep 19, 2010 | Whirlpool GGQ8831L Gas Dryer
The dryer does not heart
is it gas or electric?what's the model number?if you checked the thermal fuse located on the blower wheel housing and that's ok,check the heating element with a meter,if it's gas you have to read out the ignitor,the sensor and the gas coils with a meter,if it's gas and you have parcial heat change out the gas coils,did you check the thermal fuse part 3392519 or on some dryers it's a 3390719 with a meter,if you did you have to remove one of the wires to get a true reading on anything you're reading out,also unplug the dryer before you check these things,also when you clean out the dryer you gotta take off the duct that the lint filter slides into and vac out the inside of the dryer,if the vent line is long,i use a leaf blower to clean out the line,remove the line from the dryer and the wall,stick the blower in the hole in the wall and blow the line out from the wall to the outside hood and make sure nothing is blocking the hood like a cage,some hoods come with a cage so animals can't crawl up the line,if you have this you gotta clean the cage every month,if you need more help send model number and if it's gas or electric
Dec 19, 2009 | Kenmore Dryers
GE Profile Gas Dryer - Heat goes on and off
The operating coils get hot and quit. They only cost 20 bucks. Read more about it here:
Gas dryer works then quits then works some more
Mar 31, 2009 | KitchenAid KGYS850LT Gas Dryer
Dryers Logo
581 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
