Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Signal board Hey wich one is the signal board? Also PTS quoted me $249 to repair the format board, I am pretty sure that that one board was my problem, I checked over the rest of the boards and other than a few bloated Caps They looked fine, I am in the process of replacing those caps and just waiting on the format board to return from repair.....thanks James
  • 1 more comment
  • xx007xx Sep 24, 2008
    do you mean the one that the cable card inserts into? if so I looked over it really well and changed out the 4 - 16v 1000uF capacitors for added insurance, I am gonna go ahead and put the tv back together without sending it out because they told me that they did some work on the format card and that tells me that that is where the problem lies, I also changed out the four same caps on the power supply card(two of them were bloated out and were about to go) thanks James
  • xx007xx Sep 26, 2008
    Well thank you very much, I just got my format board back from PTS and it costed me 264 dollars, but I am happy because five hours later I got the TV back up and running like a champ, glad to have my big screen back, thanks.......James
  • karimatuszyk Oct 01, 2008
    can anyone help me on tearing my tv apart..i got a wd52525 and can't get into boards cuz of silver covers..please help..my email is karimatuszyk@yahoo.com...thanks
    Problem Solver:
The signal board is the one all the way to the left it has the one with the cable inputs ..1 to 3 (LF to RT) 1 = Signa board,2=DM board,3=FMT board....
Posted on Sep 24, 2008
  • lancergsr00 Sep 25, 2008
    ok give it a try, if it still have a problem try to check the signal board its the one with the coaxial cable ,the one where you connect the cable tv box ....
Drain plug has nothing coming out.
it has no oil, dont run it dry
Aug 09, 2011 | 1999 Jeep Cherokee
Main board malfunctioning where can I get a replacement part? left part number at work - believe it is 933B86600
The boards are no longer available from Mitsubishi, which board (signal, deflection, power) are you looking for?
A national company called PTS ELECTRONICS does repair some boards.
Let me know actual problem and I can advise.
SD TECH (San Diego's #1 Mitsubishi tech)
Jun 02, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Screen went completely green
Hi
Problem could be in the SSB/signal board causing no picture. Encompass Parts 1-800-638-3328 PTS this company rebuilts boards 1-800-844-7871. If you know how to solder ,then resolder the Signal Board its the one that has Cable connector on it.Sometimes poor solder connections will cause this problem.
Thanks for using Fixya.
Apr 28, 2011 | Televison & Video
L have a 32" vizio
I have had this problem, the main board has usually been the culprit. If you open the back, Check the fuses on the main board, you may find a blown fuse. Get the part number of the board, I suggest Moduslink PTS, they may have what you need, they also repair the boards if you cannot. Good luck
Jan 05, 2011 | Televison & Video
Hitachi model 50v71discolorization on the screen
You have a small signal board that needs reworked. Also known as the convergence board. Send off to PTS Electronics.
Sep 15, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Where can I get a Mitsubishi Signal Board 930b881001 New or repaired
boards for these sets are never available any more from Mitsubishi----google PTS---they repair, rebuild all kinds of circuit boards.
Aug 06, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Whats with my tv?
Good Day;
Replace all caps that are swollen, but resolve your checker pattern:
1. Tile or block pattern replace D8F00 and D8F01 part # 264P828010, also replace C8F26 and C8F29 part # 141P148000 (1 uFD, 25 V) on the FMT PCB (part # 930B924002).
The diodes have a stripe (line) that is the cathode, at one end of the device, the board will reflect that line. Good Luck, big IRISH. PS ; De solder as best as you can, glue is under part, heat one end, while prying up, heat other end. It will come off with moderate to mid high heat.
Sep 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replace conversion board
Signal / Main PC board AKA the "A" board is send for repair only = PTS corp ....Part # TNPH 0370.....250.00 Approx.
OR
Replace IC7001 & 7002....STK392-110 and inspect resistors.
If you have good electronic repair skills,you might attempt to
DIY...otherwise, hire a senior tech,if possible...............T.
Feb 06, 2008 | Televison & Video
Dvd plays fine sound/picture...No sound or picture with cable input
John,
To answer your question no, there are no fuses associated with the tuner input - through the "F" connector jack.
You have there a V26 chassis which has, among other things, standard digital and analog signal inputs. If one works but not the other - and you've verified it's not the cable then the only alternative is the signal board, Mitsubishi p/n# 930b923002...
But don't rush out and buy this puppy, it's a fairly expensive board and there are alternatives to replacing it new or used - PTS Electronics can rebuild this board for half the cost of a new one and most techs use PTS for that reason.
My best advice is to have a qualified shop estimate the repair and if they decide that the signal board needs to be replaced and quotes you a price ask them then about having it rebuilt.
Also take the unit to them to save the pickup/delivery charges and ask for your estimate in writing...
Hope this helps!
Bill
Dec 06, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
314 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
