Question about Sony Playstation 3 (PS3) Console
Home screen color
Whtas up GAMEFIXER? Have you ever had a home screen turn from black to a somewhat yellow color? Did I mess with some setting or is something else messed up?
  • 344 Answers
Yes, the home (XMB) does turn color depending on the time of day. This is a default feature. I haven't seen it yellow that I can remember. But check it at different times and make sure it is changing to other colors as well.
Posted on Sep 24, 2008
New rca rtd3276h DVD home theater system only displays black & white , no color . Already tried different cables & I see nothing in menus about color. Help !!!!!!
There has to be a control for color level - look for it. If adjusting it does nada then something is messed up with your color circuits on tv.
Nov 14, 2015 | RCA Audio Players & Recorders
I somehow changed my background color to black instead of white and from black to white lettering! I was messing with my settings online on my Google accounts, and nite I can't figure out how to change it...
Hi, I'm not sure if you mean your print setting - or if you mean your screen is now reversed (night reading feature). I'll try to briefly answer and if not - perhaps you can write again with a little more info. My first guess is that you'd like the night read feature, switched back as pasted here. If SO but you need more info - you might search "how to turn on (off) the night reading feature" on the specific item you are using. This link is for same - on a tablet-and it's to turn it ON. Same steps - to turn OFF (pasted after link):
http://www.labnol.org/software/ipad-night-reading-theme/20538/
Use the Dark Theme for Night-time Reading in any App! iBooks or Instapaper aren't the only apps where you read content. There's your RSS feed reader, your email client and even Safari where you read web pages. Wouldn't it be nice if you could bring iBooks style night-reading mode to all the other apps on your iPad /iPhone? There's an easy workaround.
On your iOS device, tap the Settings icon and choose General - > Accessibility - > Triple-click Home and and set it to "Toggle White on Black."
Press the Home button to exit Settings and launch any reading app. Triple-click the Home button on your iOS device in quick succession and it should enable white-on-black effect quite similar to iBooks Night mode. Triple-click again to switch to normal mode.
Aug 20, 2014 | Office Equipment & Supplies
After the dvd plays for like 10-15 minutes(when dvd player warms up?) all the colors on the screen turn to black, yellow and purple for the rest of the movie. What's wrong?
I gotta know more clearly about your question, i am going to explain in 'Guide Solutions'
Guide 1: Is it the color just cover the main grid? (Color cover like blocking the others, such as watching 70s TV shows, the colors blocked in black and white.)
Source 1: Audio input problems, your dvd audio input linked with three different 'rops', they are appeared to be push by pressure.
Solution 1: Determine more spaces to them!
Guide 2: Is it the color cover the photon grid? (Color cover at all pictures, each of them doesn't stand the other colors instead of replaced by unique color)
Source 2: Undefined
Solution 2: The TV setting menu seems to b set by specific colors, change it on your own using remote. OR this is a specific part that the DVD need to show the color in unique color (only one)
(No problems, keep watching)!
Jan 22, 2011 | Panasonic Home Theater System System
JVC 32" D series TV is suddenly black and white
Wow that's interesting, was there anybody watching your home while you were gone? There is a possibility that someone simply turned down the color level with the color control? Check that first. It's an unusual symptom. With composite video, component video or HDMI it's not usually possible to experience that defect. Since the color (chrominance signal) is usually inseparable from the luminance (black and white signal) I would check the color setting first. Other wise your set has become unable to detect that color signal... I bet it's a setting rather than a defect.
Happy Viewing
Zashiban
Jun 28, 2010 | JVC AV-32260 32" TV
Panaonic Home Theatre DVD system only plays movies inblack white
Check the region and picture settings on the home theatre's dvd player, it could be set to put out a component signal, or it could be set to a PAL region rather than NTSC
Jul 06, 2009 | Audio Players & Recorders
My dvd theater system has no color
some times the dvd's change by itself to PAL/NTSC system so you need enter to set up and select the option in system tv NTSC for America users. Make shure conect yellow cable in the yellow conector.
May 25, 2009 | JVC TH-C5 System
Big yellow spot in the middle of the screen
the lcd panel for the blue is bad normally you would have to replace the engine but i know a place where you can get it rebuilted for a price cheaper than the engine go to
N-home tvservice.com for some answers
Mar 02, 2009 | Hitachi 55VS69 55" Projection HDTV
I'm not getting any color pictures in my home theater system
Well, assuming were talking about a dvd player with dvd's,you dont specify what type of cables you are using to conect it to your tv, it appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Thanks...
May 23, 2008 | Audio Players & Recorders
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
No color on xbox
i am having EXCATLY the same propblem except its color on my pc but on everyother tv ive tried its black and white except one but i dont know why
Dec 29, 2006 | Microsoft Xbox 360 Console
Sony Playstation 3 (PS3) Console Logo
54 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
