Question about Refrigerators
Amana SCD23VBL Side by Side. Evaporator froze up! Pulled circulating fan and it checked ok. Measured voltage and it was approximately 57 volts. As the coils defrosted the voltage started to and continued to climb. Last reading it was near normal at 112 Volts.
  • 1 more comment
  • z503jc Sep 24, 2008
    You're problem and mine are probably very related. Pull the inside back panel and I believe you will find you are iced up also.
    I believe my voltage comments may have been misleading. Those were open circuit voltages however I still do not understand why they climbed.
    FYI: Years ago I was a certified Amana Refrigeration Repairman.
    I'm not looking into the defrost timer circuit.
    My problem ended up being the Defrost Terminator. This is a device which senses when the freezer compartment has reached some specified temperature. At that point, in this Amana, it opens which disconnects the defrost heater and also stops the circulation fan allowing the evaporator to frost up. When the temperature has dropped enough, the Defrost Terminator resets allowing normal operation. Good Luck!
  • cafezinho Jan 12, 2009
    Unit ices up and does not keep cool properly in both sides. The water dispenser freezes and and they have to turn it off to get that to thaw out then start over same.
    My daughter has this problem the repair man replace the thermostat and defrost timer and still the same.
    The fan spins when the cycle calls for it the best I can tell.
    What is the defrost limiter and where is it.
    Isn't it the same as the defrost timer ?
    Appreciate your help !
No water to door but the waater in icemaker still works. when I press the button for water I get no respse.
Posted on Sep 24, 2008
I have a Amana fridge that the evaporator fan is not running. model no. SPD26VW Also have replaced the following defrost timer and defrost thermostat. I have about 0 volts at the fan. Removed the fan and...
There may be damaged or broken wire to the evaporator fan
There are two wires to the evaporator, one hot and one neutral Unplug and check the neutral against ground with a continuity tester if ok test the other wire in a non invasive fashion using a safety pin
The way you do is to insert the pin say at several points on the wire until you discover where the break is. Use alligator clips, one is to be connected at the connector of the fan hot wire ( The suspected wire that may be broken) With alligator connected at the end of the wire connector, insert the pin at different points to check wire integrity with an ohmmeter. Where there is no continuity, that is where the break would be.
If that does not work, you probably will have to run a new wire. Here is a hint: The evaporator fan runs only when the compressor is running. If you can extrapolate, you can find an alternate way to reconnect the evaporator fan and have your fridge running in no time.
Dec 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Voltage to evap fan 94v not working runs slow @ 120v
Hi, I deal with evaporator motors on a day to day basis.If the motor is running but not up to full speed, the inner windings of the motor are going out. If the motor runs as you say, is it getting only 94 volts to it? If this is the case, check the incoming voltage to the unit itself. Check to see on the schematics what is between the motor where you may be loosing your voltage. Defrost thermostat, or timer. Check power to the timer first and get back to me. The defrost thermostat supplies power to the fan when the evaporator temperature gets cold enough and the contacts will close and send power to one side of the motor. If it is going bad, it will cause you to loose part or all of the voltage. If you have a meter, check this. It is round and sealed with 2 terminals on it. If it is cold enough, you can check the leads to ground and see if you are getting less then 120 volts coming out the motor side. If so, replace the thermostat. Please keep me posted.
Sincerely,
Shastalaker7
PS Be safe around electricity. Also, this defrost stat snaps around a evap. line.
Dec 28, 2009 | Amana Refrigerators
Refrigerator side is not cool, although setting is same as always (4) I changed setting to 5, but after 12 hours, it is not cooler. Freezer side is working properly. I checked to be sure air vents are...
There are a couple to possibilities.  Either the Evaporator coil is iced over or the fan is not circulating air.  All of the cold air comes from the freezer if no air circulates the refigerator will not get cold.  check to see if the evap coil is frozen over.  If it is deforst it with a hair dryer.  for continuity with an ohm meter if it is open replace the heater if not check the defrost thermostat.  If it is open replace it.  If not replace either the defrost board of the defrost timer depending on which it has.  If it is the fan not working check for voltage going to the fan.  If you don't have any replace the defrost timer
Oct 25, 2009 | Amana ARS2464B Side by Side Refrigerator
Ammana Fridge-Evaporator Fan not working
Replace the defrost bimetal . On older Amanas' , the coil has to be cold , before the evaporator fan starts ( bimetal closes ) . This way , heat from the defrost cycle , will not be blown into the refrig section .
Oct 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My Amana Side-by_Side SXD26VL is not cooling. The
clean cond coil at back of unit.
check amp draw on the compressor wires.
Sep 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Amana Refrigerator SCD22JL
Good trouble shooting TD, the evap fan runs through the defrost T-stat. Change it out and you should be set. Catriver.
Aug 14, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
