Had professional install of new Panasonic 50PZ80 & Panasonic PT560 Cinema Surround Sound 2 wks ago. All great until we upgraded to Sky HD y'day by Sky - now get bad lip synch on most HD channels - SD channels OK. Adj of Digital Audio Output Delay only makes it worse. Sky say they can't help, & say "it's a known fault on certain Pace boxes" -they won't say when they can fix it nor will they supply a replacement digibox. Threats of reporting them to Trading Standards have fallen on stony ground. Is there a fix out there? Plse help if you can. Many thanks.
  • 1153 Answers
SOURCE: Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Posted on Aug 22, 2007
TVtechmaniac
  • 140 Answers
SOURCE: Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Posted on Aug 25, 2007
SOURCE: surround sound
You need a cable from your audio outlet to the home theatre receiver. Veira link is just for the picture. Only one way transmission. Optical cable or the 2 wires. Both options are available.
Posted on Dec 17, 2007
  • 24 Answers
SOURCE: Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Posted on Aug 20, 2008
SOURCE: I have installed a Techwood
Have installed a brand new Gold Plated Scart Lead (original Scart was probably defective). Incidentally this is not a Projection TV but an attempt to prolong the life of an old-fashioned Cathode Ray Tube.
Posted on Oct 20, 2008
Sky eye red light on but remote won't work
You are using the new remote and not the old Sky remote aren't you
Oct 12, 2017 | Televison & Video
I have a panasonic dvd home theater sound system SC-HT880 and i have just upgraded my tv from a Samsung 42 in Plasma to a Samsung 50 in 3D ready tv and i can not get the dvd payer to work in tv mode by...
Hi
Have you resolved this issue yet? I am in a similar position. recently upgraded my TV to a flat screen, also purchased a Blu-Ray but the SC-HT880 is now useless. How can I use the surround sound to work on TV? do I need to purchase an Amp?
Dec 31, 2010 | Panasonic SC-HT880 System
Have today bought Ferguson FHT1000 5.1 Channel DVD home cinema system can i get surround sound to work on tv or will it only work on dvd
it will work with your tv providing your tv has the correct output and you have the right cables. the programme must also be broadcast in surround, most programmes are only stereo. if you are running sky or sky hd this will be different so repost.
Dec 20, 2009 | Audio Players & Recorders
How do i connect to sky hd and sony kdl 40w 4710 and dav-is10 i have hdmi from skyhd to tv and hdmi from home cinema to tv what else is required as i cant get surround sound from tv
you need a Optical audio cable, run this from the back of your Sky HD box to the Surround sound. Not all Broadcast are transmitted in DD so press your i button on the sky remote and you will see this on the yellow bar above the program information if it is..
Might be worth running a set of White and Red audio cable from the HD box to the Surround sound as well that way you can just mute your telly and have the lot coming through the surround sound system.
Hope this clears things up for you
Little Dish Fitter
Jun 05, 2009 | Sony DAV-IS10 System
5.1 sound from Sky hd through LG TV
link your optical cable from your HD box to your surround sound.
Then if you go into your HD services menu, press 4 then go to sound make sure its set to Dobly D
That should sort your problem out
Cheers
Little Dish Fitter
Feb 24, 2009 | LG 37LC7D 37 in. LCD HDTV
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Friend gave me a jbl surround system to go with my 52" sony hd tv. It has four speakers. three sat 20 and one bass 20. going to a rca stva 3970 receiver. didn't have instructions to go with it.
You need two more speakers to get surround sound,ie> two front one center and two for surround,then you need a home cinema amp to run the speakers and decode the sound from your tv,sky,dvd etc,and the sub gives you your bass.
Hope this helps.
CABLE GUY.
Nov 16, 2008 | JBL 5.1-Channel Home Theater Speaker...
How to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Surround sound from Sky +
To upmix 2-channel sound (such as that in a TV broadcast) into 5.1 sound, press AMP and then SUR. DECODE until "PL II Movie" is displayed. This will give you "cinema-like" surround sound from a 2-channel source.
You can also assign this to one of your "Scenes" by following the procedure for scene assignment on page 26 of your manual.
Dec 30, 2007 | Audio Players & Recorders
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
