Question about Daewoo Microwave Ovens
Daewoo microwave that won't cook
I have a microwave that is not working properly. the pizza cooker cooks just fine with no problems. the microwave panel seems to be functioning. it seems to power up, but the plate inside does not rotate and it does not cook. any suggestions?
    Scholar:
  • 136 Answers
More than likely a door switch inside the unit is misalligned or faulty. Crack it open and check for proper allignment and good open/closed circuits with a VOM.
Posted on Sep 24, 2008
I have a Hot point EM925RCW 900 watt micro wave in my RV. My preset cooking buttons, (popcorn, potato, pizza, nor time cook) will not work but the number cooking works. Syggestions
I would guess either the circuitry for part of the keypad is defective or prehaps more likely the unit has developed amnesia because either the supply to the programmed memory chip is broken or the chip has failed.
It really amounts to the same thing as almost all those components will be on a single board and the repair guy is unlikely to worry about what is wrong but will simply replace the board.
The question is how much is the luxury of presets worth to you and will a repair be significantly less than the cost of replacement?
Jun 13, 2016 | In Microwave Ovens
How to bake pizza in rival micro wave .??how to set it?
Unless the pizza was specifically packaged for microwave use, pizza cooking in a microwave is usually a bad idea. They don't turn out well. Although microwaves are referred to as "ovens", they really don't bake things, they boil them by heating the moisture in the product. Thus, pizza crust will not rise and get crispy unless the pizza was pre-made to be microwave reheated. Those pizzas will give instructions on how to microwave them.
Nov 06, 2015 | Rival Microwave Ovens
My GE OTR Microwave Model # JVM3670SK02 overheated when I tried to cook rice for 30 minutes...two times in a row. What could be the problem?
why are you cooking rice for 30 minutes in a microwave????? the problem is that a microwave IS NOT A RICE COOKER!!!use a rice cooker or use instant rice and heat the water for 2 1/2 minutes only!! OR BURN DOWN YOUR HOUSE!!
May 08, 2015 | GE Microwave Ovens
Panasonic microwave
I would check the cooking instructions on the side of the pizzas packaging. If microwave cooking is not listed I would not recommend cooking it in a microwave as this could make the food unsafe to eat.
But if you're short of an oven I have found a guide on barbecuing a pizza:
How to Cook Pizza on Barbecue
Mar 20, 2014 | Avanti Microwave Ovens
Bake pizza
I would check the cooking instructions on the outside of the pizza packaging. If microwave cooking is not a suggest method I would not try to cook it in a microwave.
Mar 20, 2014 | Panasonic Microwave Ovens
Food in microwave is burning on edge and cold in the center
you may find the old unit was lower watts so took longer & cooked/heated better all the way through. a way to fix this is lower temp settings or pause and stir the food to help heat it up more even.
Dec 29, 2013 | KitchenAid KHMS2040BSS Stainless Steel...
Burns my popcorn constantly. is there a different setting i can put it on?
HELLO.
Solution to your microwave problem is given as below.
* 1 Set your Daewoo microwave on a countertop near an electrical outlet and plug it in. Open the door and place the circular roller guide in the center of the oven cavity, then place the glass cooking tray over it.
* 2 Set your food on a microwave-safe dish and then put the dish on the cooking tray and close the door. Make sure that it latches properly.
* 3 Turn the upper knob to select a power level. Power levels include "Defrost," "Med-High," or "High." If your Daewoo has a touch pad, touch the "Microwave" button once to set the highest power level. Touch it consecutive times to lower the power level.
* 4 Turn the lower knob to set the cooking time. For cooking times less than two minutes, turn the knob up past the two-minute mark, then back to the correct time. For touch pad models, enter in the cooking time with the numerical keys and then press "Start."
* 5 Open the door at any time to stop the cooking and check the temperature of your food. Shut the door to automatically continue cooking, or turn the timer knob to the right to add more time. For touch pads, press the "Stop/Clear" button, then key in a new cooking time and press "Start."
* 6 Open the door when the timer reaches the "Off" position and take out your food.
Thanks.
Sep 24, 2011 | Daewoo KOC-925T Microwave Oven
Emmerson microwave oven and grill
mcdevito75 here, Follow the directions on the frozen pizza package, Or simply microwave at 2 minute intervals till the pizza is done or fully heated up.
Jun 22, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Egg cookers
I found the instructions
Sprinkle a few grains of salt on bottom of egg cooker. (Salt attracts microwaves and is necessary to help cook bottom of egg)
Break egg into egg cooker.
One egg in micro at a time.
Will fork piece yolk and white to bottom of cooker, three times. _ This is very important.
Line up notches on egg cooker lid and cup then twist until locked
Micro on High for 30 seconds
Let stand 10 seconds
If bottom of egg is not cooked turn egg over with a spoon and microwave on high for another 10 to 20 second or until cooked.
Dec 16, 2008 | Microwave Ovens
Microwave Ovens Logo
169 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
