Question about Whirlpool RBS275PD Electric Single Oven
Whirlpool avm 689 combi oven err1
Hello, I have a Whirlpool combioven type avm 689.
The problem is when I close the door there is a humming sound (I think it is the condensator) and the display says ERR1.
Funny thing is the display is working fully when the door is opened.
What can I do ????
Kind regards, Bas, Netherlands
  • Anonymous May 05, 2009
    I've the same problem, but when I open the door, my oven starts. When I close the door the oven stops and the display says ERR1.
    Esther, the Netherlands
SOURCE: Oven door stays slightly open
The unit may be out of plumb ( square to the floor ). I suggest you get a level and make sure the stove/oven is level and if it's not, there are some levelers ( where legs would be on the bottom ) that can be adjusted with needle nose pliers or a cresent wrench. If this doesn'e work, you may have some hinges sprung and need to replace them. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
  • 619 Answers
SOURCE: Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Posted on Jan 22, 2008
  • 56 Answers
SOURCE: WHIRLPOOL SELF CLEANING OVEN DOOR WON'T OPEN
replace the clock f1 is a watchdog on the board
Posted on Jun 30, 2009
SOURCE: Whirlpool Oven Died During Cleaning Cycle No Display Now Locked
Had same problem with my KitchenAid. 10 years old. Ran self cleaning cycle, oven died!!!! Called repair. Appears to be thermal fuse. Part on order. Microcomputer had some brown spots on it. Tey wanted us to replace it too. But will wait to see if fuse is problem. Repair - $150 vs. $570. If it's the higher price, we'll buy a new oven before putting that kind of money into it. Will NEVER run a clean cycle again even if I have to buy a new oven.
Posted on Dec 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: From "bake" mode, oven door locked, both heating elements on.
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^
Posted on Oct 01, 2010
I have a rational combi oven electric 3 phase model number cd61 can anyone help that when should the oven fan motor start after the oven is on and how to test the motor
The motor should start as soon as the door is closed.
to check the motor, I need to know the s/n. Some motors use contractors, others use electronic motor control.
Apr 20, 2016 | Combi Ovens
Trying to clean my whirlpool oven. when it start button, an E1 - F5 comes up. What is this telling me.
What the F5-E1 error code means is that the door lock asm. is not operating so when its suppused to close and lock the door to self clean it cant do it since something is wrong with the latch/lock assambly
Some of the things that would need to be checked to see why the latch isn't working are;
the latch position switch,the latch itself to be good and opening/closing, & the part called the soloniod that is what operates the latch so it could open or close
GENE
Sep 18, 2011 | Whirlpool Ovens
My oven light on my acubake whirlpool oven will not turn off it just beeps
Hello & Welcome to FixYa
The beep sound in oven is caused when either the door latch mechanism goes bad or the control board itself is bad. First check the door latch...if the problem is still there then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | Whirlpool RBS275PD Electric Single Oven
Oven door not shutting fully
Make sure there is nothing trapped at the bottom of the door to prevent it closing properly.
If nothing obviously wrong, then you will probably need to replace both oven door hinges as the door springs are probably weak.
A common problem with this type of oven with a drop down door.
Dec 18, 2010 | Whirlpool RBS305PDS Electric Single Oven
Door will not stay closed
Hello,Sounds like the door hinge springs are weak, it will probably be necessary to replace them both.
Thanks
Jun 02, 2010 | Whirlpool GBS277PDS Electric Single Oven
Self cleaning oven
Hello, check door switch,contact should be closed when plunger is actuated.check door circuit for open.
Thanks
May 27, 2010 | Whirlpool GBS307PDS Electric Single Oven
The oven door on my Whirlpool oven won't stay closed
Sounds like the door hinge springs are weak, it will probably be neccessary to replace them both.
Please leave feedbck
Dec 06, 2008 | Ovens
Oven door won't close tightly
Sounds like whoever installed your oven hasn't adjusted your door properly and as a result over time probley got worse? any way there should be 3 screws on each hinge the top and bottom screws hold the door in place the screws under the top ones are used for making adjustment with a Philips head screw driver open the door and try screwing in clockwise 2 or 3 full turns and with your free hand feel if the door is moving upward if so repeat the same on the other side and then close the door and see if its made a difference if so and its still loose try again if its made it worse the turn the screws in the opposite direction Let me know if this works
Dec 09, 2017 | Whirlpool RBS305PD Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
429 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
