No sound from my HP G6000 Notebook PCs internal speakers, (mute is not on) although sound is going through a set of external speakers. Checks have been carried out on all sound settings which state speekers are working.
  • Anonymous Dec 07, 2008
    i have checked all of my speaker setting and its still not working. ive done a system restore and tht hasn't worked its not on mute
    HELP
    IVE GOT A HP G6000
  • Anonymous Apr 17, 2009
    I have the same problem, also with the HP G6000. I think my headphone jack and/or contacts are damaged... I know it may sound weird, but try blowing into the headphone socket. Sometimes works for me.
    Champion:
  • 200 Answers
Well since the external speakers are working then the problem is with the internal speakers and thats a hardware issue so they need to be replaced if you have warranty then take it in to be fixed nothing else can be done
Posted on Sep 24, 2008
How do you un-mute tv settings
Try pressing the mute (speaker symbol with diagnol line) or just press up/down volume button
Sep 08, 2014 | Televison & Video
External speakers won't work on HP T5570e Thin Client
Try to use earphones, plug them in to phone audio connector....
try if it works..... if so, disconnect them and plug speakers.... and try again.... if doesn't work, go to audio advanced setup and check if speakers are not muted, or set up voicevolume level is too low. Play with that setup....
Also some computers can turn on or off speakers in Bios.
If problem will not be solved, try to use USB speakers
Jan 13, 2014 | HP T5740 Thin Client Desktop PC
(hp Pavilion g7-1150us notebook PC) The problem is that the left internal speaker, of my laptop is completely mute, only the right internal speaker is functioning. I discover it when I checked the speaker...
It could be defective or shorted. Replacement is too costly. I would use an external format, plug a set of speaker into the Audio Out on the side of the computer. EXTERNAL Speakers from Logitech
Feb 09, 2018 | Computers & Internet
Our notebook sound is gone. but when we connect external speaker then sound come so please solve the driver problems as soon as possible.
if you sound comes on when external speakers are plugged in chances are its not a driver issue you internal speakers could be blown if they were blown you would still hear distorted sound coming from them
is you internal speakers on mute? or maybe on really low volume
you can also go into my computer right click on background hardware tab device manager
and if you dont see anything with yellow question marks over it its not a driver issue
im almost certain its a volume issue with your internal speakers
Feb 05, 2011 | Computers & Internet
My laptop has sound drivers but there is no sound being produced,whats the problem?
first make sure the audio hardware your using if external works properly hooked up to another source if so its your audio drivers or sound settings if not than its the speakers if the speakers are internal it may be a sound setting if your using a mixer make sure none of your line out or sound setting are muted if thats not the case going into your device manager and troubleshooting the sound drivers you have would be next if it still has no sound I would suggest re installing the software that came with them after uninstalling and restarting computer
Mar 31, 2010 | HP Compaq Presario V2000 Notebook
External speakers do not work on my MacBook pro
Plug in your external speakers then go to system preferences then sound when in the sound control panel go to the output tab and select the external speakers as the device for sound output and of course at the bottom of the control panel make sure that the mute check box is unchecked and turn up the volume. Hope this helps
Oct 08, 2009 | Apple MacBook Pro Laptop Computer with...
I have no sound on my hp pavilion entertainment pc laptop. No sound, but a click each time I mute or unmute. i have re-installed drivers. All checks out -- except no sound.
you have to check the audio controllers from control panel too,, and make sure,, you are well connected to external speakers,, if you have,, or else first make an check with headphones for sound checking,, then you can analyse if it works,, then there internal speakers problem.
Sep 27, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
My Dell Inspiron 6000 stopped playing sound. I uninstalled and reinstalled SigmaTel driver. This did not work.
Does it show that the device is working properly in the device manager? You could try and use system restore to roll back windows to a time when the sound was working. Windows may have updated software and caused problem with audio. If you roll back the system to a time when you know the sound was working then the on board audio may be defective. Have you tried plugging in headphones in the headphone jack and check if there is sound? Are the sound properties muted? The laptop speakers or internal amp may have stopped working also.
Sep 10, 2009 | Dell Computers & Internet
Hp dv71245dx cannot remove from muted state.
hi
Go to Control panel > Sounds and Audio Devices > Volume. Check that Device Volume is at least halfway across the slider and that Mute is unchecked. Go to Advanced and make sure that nothing is mute. Go to Speaker Volume and set the sliders at least halfway across the slider. Go to Advanced, and in Speakers setup choose Laptop Stereo Speakers (if that's what you have). Go to Performance and choose Restore Defaults. Click Apply > OK
plz do inform if this has sorted out the problem
all the best
regards
Jul 15, 2009 | HP Pavilion dv7-1245dx Notebook
External speakers don't work but internal speaker works fine.
Try your speakers on another system to make sure speakers are working.
Make sure volume control on PC is not set on mute.
Make sure onboard sound is enabled in BIOS
Try re-installing the sound card driver.
If all this fails and you have a spare slot on your PC just purchase a new sound card for about $10.00 or so.
May 21, 2009 | HP RT987UAABA - HP Compaq dc5700...
Computers & Internet Logo
245 people viewed this question
David Payne
David Payne
