Question about Samsung AS18A6RB Air Conditioner
Split air conditioner
My split air conditioner comperseor will be off after 1 or 2 hour after turn on. We change the compersor. New comperesor have this situation, again. Why? How can we fix it?
let know me by mail
siroosjafari@yahoo.com
Try to change the compressor proctection circuit, if ther is no problem with the compressor protection circuit most probably the compressor motor capacitor leakage problem r defective capacitor.
Posted on Oct 14, 2008
LG split unit AC works perfectly for 2 hours and then it stops blowing cool air
Check the amp draw on the condenser fan motor against the rating on the nameplate. motor may be getting weak and shuts down on thermal overload. If the amps are high you have a motor going bad, change it.
Aug 06, 2012 | LG Heating & Cooling
Have an LG split system air conditioner. No way to turn it on or off on system. Remote only and it is not working. Did this a week ago and changed batteries, took a while before new batteries worked as...
Before buying new one, try with this step. Remove batteries from your remote and reset it after 5 minutes. And also remove DC wires plugged to indoor sensor display, and after 5 minutes re set it again. Now start your unit. Sometimes it will work out. Thanks.
Feb 02, 2011 | LG LSC121PMA Split System Air Conditioner
MY LG 2 TON INDOOR UNIT MAKES NOISE AFTER 2 HOURS OF STARAT FOR 20 SECONDS AND SOUND DISAPEARS ITSELF BUT AGAIN AFTER 10 MINUTES NOISE REAPEARS AND SAME SITUATION CONTINUES TILL ITS COMPLETLY SWITHCHED...
The compressor is locking up....the start relay and capacitor maybe the problem...I would have them changed first and then if that don't help the compressor will need to be changed out...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 08, 2010 | LG Heating & Cooling
Problem with compressor
Normaly on this units the problem is the PC boards if i'm not mistaken they have censors this censors give problems sending the unit to a Protection mode when the units works too hard sounds like thats your problem room 2 big and the High preasure presostat it's telling the unit to stop.
May 27, 2010 | LG LS-L1210CL Mini Split Air Conditioner
My fujitsu split system blows warm air after about
There is not really enough information here to properly answer your question. I can make a couple of observations for you though. 1. Compressor, yes this could be the problem, but it is not quite that simple. Is the compressor running when the hot air starts to blow? 2. Capacitor, no I don't believe this is the problem, as if it were a capacitor problem, chances are the unit wouldn't even start. 3. Gas leak, again no, if it were a gas leak, then you wouldn't get an hour of good run time when the unit starts up, repeatedly. Hope this helps.
May 07, 2010 | Heating & Cooling
Split ac not cooling the room.ac temparature remains at 27 degree after ac runs for about 4 hours.please solve this
Gas has leaked from inner or outer unit kindly get it checked by service men they will find the leak and charge the gas again normally after some time it gets rusty inside as water is involved and got leak
no problem get it repaired not expensive
pls rate me well !
Regards
Jul 14, 2009 | LG LS092CE Split System Air Conditioner
Split Air Conditioner Compressor Start Problem
you need to change it again.
rememper that I am not rich enghe to by the cheep
May 24, 2009 | Heating & Cooling
Stand By Mode
1. use remote properly
2.first off the unit then again the unit
3 if same problem change remote by new one
Mar 18, 2008 | Sanyo 24KS62R Cool Mini Split Air...
Samsung AS18A6RB Air Conditioner Logo
122 people viewed this question
Top Samsung Heating & Cooling Experts
Nyte_Ryder
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
