Question about Panasonic KX-T7630 Corded Phone
Calls go directly to voicemail
As stated above, I've looked through my reference manual and I can't find anything to let me know how to reprogram my phone so my phone will ring instead of going straight to voicemail.
  • awheaton Sep 29, 2008
    It was actually set to automatic attendant so I had to go into voicemail, press option 4 and then press option 1.
  • Panasonic Master
  • 2,460 Answers
You have a FWD/DND button on the top of the phone. Press it and read your display. One of the choices is FWD with a destination displayed, one is DND, and one is Fwd/DND Off :-)
If you don't have DND set, it will only toggle 2 actions.
You can change the time/destination by using the *7104 xxx # where xxx is the voice mail system. 7104 is the CF No answer code (5 being busy/no answer and 2 being all calls and 3 is busy alone). *7100 clears it all.
In case you wonder what happened to *7101...it's Do Not Disturb.
Carl
Posted on Sep 24, 2008
  • Carl Navarro
    Carl Navarro Sep 29, 2008
    It's not very often that customers get into the mailbox and set all calls forward to mailbox. In fact, I can't think of *any* account that has ever done this. That's what 7102 on the phone is for. You must have done it remotely or by accident.
    Carl
Mobile phone,all incoming calls go to voicemail,without ringing
you did not provided what brand, model and year, therefore you need to read your manual...
you need to find in your setup section and enable calls, setup as to re-direct to voicemail after say 5 rings, enable ring.
unfortunately without model and year - more detailed directions cannot be provided...
Feb 08, 2015 | Cell Phones
My calls go directly to voicemail on edge 120
Normally when calls go directly go to voicemail, there are a couple things why this happens:
- Extension are unavailable/busy
- Call forwarding/Do Not Disturb are on.
If you do have call forwarding/Do Not Disturb on, please consult your user's manual for detail instructions since there are several options for call forwarding (Forward All Calls, Forward Busy, Forward N/A, etc.).
Jul 10, 2014 | Comdial Impact SCS 8212S Corded Phone
Retrieve voicemail bell 4200
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 29, 2013 | Lands Phones
Has Sansung Pro Star DCS - phone system; Has changed offices so moved the phone system. Now For incoming phone calls, none of the extentions can recieve the calls. Has four incoming lines; no incoming...
pdf.textfiles.com/manuals/.../Samsung%20Prostar%20DCS%20Compact%20System%20Admin%..
pdf.textfiles.com/manuals/TELECOM-S-Z/
panasonicmadeeasy.com/SamsungManualsLead.htm
Above is your setup manuals.
Unfortunately it is NOT just a simple job of moving the instrument, one has to reprogram the system to "Tailor" it to everything.
You need to use the manual and reprogram the system to it's new configuration.
Mar 14, 2011 | Cell Phones
Incoming calls ring once and are told thew will be transferred and then a voice tells them goodbye
Sounds like your system lost its programming so now the voicemail ports are just like extensions, they are ringing and picking up. And since the voicemail doesn't know where the phone systemn is, it just transfers all calls to the lowest numbered extension (10)
The system needs to be reprogrammed completely.
Jan 10, 2011 | Avaya/Partner 4-Line Display PBX...
I can make calls, I can tex and I can receive tex, but when someone calls me, my phone doesn't ring or anything and the caller goes straight to my voicemail. Can you help me fix this problem pls.
What type of phone, most likely the incoming call function is disabled. I would contact the manfacturer's tech support or refer to your instruction manual.
Rylan
Dec 15, 2010 | Cell Phones
Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Carl
Aug 11, 2009 | Panasonic KX-T7630 Corded Phone
HTTC 6800 Not receiving calls in sleep mode
You want to make sure your callforwarding is on. Sometimes when you select sleep mode, the calls will divert directly to Voicemail. Plus, ensure you have signal. Without signal, by default the calls go directily to voicemail. We won't wanna miss a call here. You can follow these steps here. start
settings
phone
services
call forwarding
get settings (wait for a while)
forward all incoming phone calls (check the box)
OK
OK
Exit
In the option to forward calls, there should be an option for the amount of seconds the phone RINGS prior to forwarding directly to voicemail.
IF your HTC device doesn't have the option for voicemail, and your calls are routed else where, contact your carrier for the voicemail number. This is very important!
Cheers!
Jan 30, 2009 | HTC PPC-6800 Smartphone
Voice message, reprogramming extensions
How did you program the voicemail so a caller can not leave a voicemail to a particular extension? Line ownership? SO a call goes directly to a milbox?
How can you reprogram the voice message????? Which one, for a particular user or the main Auto attendant greeting????
You have to know the admin login to change a mailbox password.
For that, you need to know which voicemail system this is.
When you log in to check your mail, the lady says, "welcome to Partner......"
Please fill in the blanks.
Nov 18, 2008 | Avaya Lucent Partner 616 Phone
Calls go straight to voicemail
You please change the setting from answer voicemail to ring mode if you have any dificaltey refer your phone user manual book and reset the option
Jun 18, 2008 | LG VX8300 Cellular Phone
Panasonic KX-T7630 Corded Phone Logo
519 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
