Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Yellow tint on my 60V500A Hitachi
The picture hasa yellow tint looks like you're looking thru a glass of mountain dew
Please help me solve this problem
Posted on Oct 03, 2008
Probably light engine
Posted on Sep 28, 2008
Picture has a yellow tint. It's from an old video game that ran over 12 hours a day. Has new bulb. Except for the yellow, works fine.
Hello there:
The best way to describe this is what is called screen burn in.
this is very common on screns that have games or pictures that arre displayed for long periods of time without being shut down just like on a computer screen when a screen saver is not used .
there is nothing wrong with the bulb.
the yellow that you are seeing is actually burned into the glass part of the projector and the lense
so if you can and feel like you can dissasemble the projector dissassemble it and locate the glass and see if you can get the yellow tint that will be on the glass and the lense off by using some rubbing alcohol and a cottomn swab
But if it wont come off you will have to replace the lense and the glass ok
Hope this is very helpful for you
Best regards Michael
Jan 18, 2010 | ViewSonic PJ501 Multimedia Projector
Projection has yellow tint
From your description, it sounds like a problem with the blue color. Green LCD=purple onscreen, Red=cyan(baby blue) onscreen, Blue LCD=yellow onscreen. It could be a lot of dust on the blue lcd panel, or worse, might be a burned polarizer filter behind the lcd panel due to excessive heat. If you can focus on the yellow and its tons of yellow specs, its dust. A burned filter however, must be replaced. A technician trained in projectors will have to do it. The filter material is glued to a thin glass panel and is replaced as a single filter. It's a very involved repair.
Sep 04, 2009 | Hitachi CP-X251 LCD Projector
The whites are yellow and theres a yellow tint to the picture in general although not real bad. Is this just the lamp # ux21513 needing to be replaced? Thank You
The Lamp would cause the picture to be dimmer but not discolored. I would suspect the Optical Engine is causing the yellowish tint. Due to the cost of replacing, call Hitachi at
1800-448-2244 and see if they would be willing to help with the repair.
Hope this helps,
Skyassoc
Jul 18, 2009 | Hitachi 60V710 60" Rear Projection HDTV
Picture is clear but with a yellow tint .
Make sure, if your using component cables ,that they match up color for color and are plugged in.If it looks good try adjusting your colors on the TV.You can also try unplugging the TV for 5 min. and then plug it back in.This might be a TV issue.
Jul 07, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Hitachi 60V500A
Good Day, artisticpool;
Suspect loose cable see picture:
If okay suspect light engine.
Good Luck, big IRISH.
Aug 17, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
50" Hitachi Ultravision with yellow picture
Good Day, steveb13;
It stills points to yhe Light Engine. Good Luck, big IRISH.
Jul 15, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
461 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
