Question about Maytag Neptune MAH5500B Front Load Washer
Can I eliminate or at least shorten the delay on the door lock feature?
Adding in the extra handful of clothes after I've already started my Neptune is frustrating due to the fact that it locks so quickly after starting, and the delay to unlock takes what seems like forever.....Might as well go get a cup of coffee and drink it while you wait.
If the old wax door lock motors have a questionable life span anyway, is there any way to just eliminate them, or at least shorten the unlock delay on a new one? My machine is the MAH5500AWW
  • 32 Answers
Unfortunately there is no way to elimate the wax motor.do not try to jump it out,you will blow the control board.
Posted on Sep 29, 2008
Broke handle off of siemens TOP WD1200 champion, the settings are all in chinese and my clothes are locked inside. help?
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
If you have used force you have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Mar 30, 2013 | Siemens Washing Machines
Door will not unlock neptune washer model MAH9700
you will have a flap on the bottom right hand side flip it down and get your self a towel and a bowl and a saucer put the saucer just under the pump you will need to start to unscrew the pump screw slowly and close it so you can keep emptying the saucer in to the bowl ok onece all water is out of the pump you can open the door ok please make sure the machine is swicth off be for doing any thing ok
Oct 19, 2012 | Maytag Neptune MAH9700 Front Load Washer
The door is locked on my maytag neptune washer with clothes in it. I am leaving town and the clothes will be ruined if I don't get them out. I already looked for the string to release the door. No...
Try putting it in a drain cycle this may help The string should be in the front right corner of the dispenser it looks like a thick fishing line If you find it pull it but be careful the washer may have water in it so have some rags handy.
Jul 14, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Can't interrupt the washing cycle on coin operated Mah21pddww
Unplug the washer, wait three minutes for the door to unlock then do what you need and plug it back in. Should still have the time left on it that was there when you unplugged it.
Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
May 31, 2009 | Electrolux EW1000i Front Load Washer
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Detergent goes where?
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 9 years for me.
Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Adding clothes after wash started
It is best to finalise what clothes you want to wash, regarding front loaders. Or if you stop the machine, you have to wait for a couple of minutes for the door mechanism to release the lock, before u try the door. At times the door won't open for there is water in there; & if you force the door you'll damage the door assembly. So a lot of caution here!
May 09, 2008 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Maytag Neptune MAH5500B Front Load Washer Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
