Question about Sony VAIO VGN-SZ440 Notebook
Cd drive does not work
I have a Toshiba Satellite A100-049 Model with vista and my cd drive does not work, i went to the device manager and it says "This device cannot start. (Code 10)" what can i do in order to make it work again? i was thinking of uninstalling the drive and turning it off and then turning it back on, and let the laptop recognize the new hardware, will this work or is there a better method of dong this?
  • 43 Answers
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "This device cannot start. (Code 10)" . You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Posted on Sep 25, 2008
CD player will not work
Try a different CD. iIf the computer doesn't recognize it at all, listen for the drive to spin and look for a blinking light on the CD tray. These signs do not necessarily mean the CD drive isn't broken. I would find the model number of your laptop and do a search on eBay for a replacement CD drive. These are very easy to switch out. If the new one works, then you're set. If it doesn't work, there may be an issue with your motherboard.
May 07, 2011 | Toshiba Satellite Pro L300 Notebook
It doesn't work the dvd/cd drive
Here are the solution for Vista/Windows 7
click start button, type device manager in the start search box and hit enter key.
in device manager, click
+ sign next to Cd-Dvd Rom devices.
right click on cd-dvd driver and select uninstall
the driver will be missing
now run the FIXIT software provided in the following weblink
i hope it will fix the issue. if not, you should delete upperfilter or lowerfilter or both in registry editor. steps are provided in the same weblink
Apr 17, 2011 | Toshiba Satellite A205-S7442 Notebook
Toshiba Satellite M50 CD/DVD drive cannot be accessed Yellow Exclamation mark in Device Manager How do I regain access to my DVD drive?
The Yellow Ex. mark means the driver has been deleted or not installed.
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Please click on this link: -
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Sep 19, 2010 | Computers & Internet
I can't print label to cd dvd from my dvd unit
Before you can use a lightscribe facility, you must have 3 things, which are, A DVD Drive thats has a lightscribe capability/function, a lightscribe software, and a lightscribe compatible CDDisk.
From what I can see, your drive is not capable, or does not support lightscribe functionality. I tried to check everything about your system model and I discovered that the capability of your DVD Drive is this :
  • Writable DVD formats: DVD-R (6x, DL [double layer]), DVD-RW (6x), DVD+R (DL [double layer]), DVD-RAM
  • CD formats: CD-R (24x), CD-RW (16x)
Which means your DVD Drive does not support Lightscribe facilities.
You can also check everything about your system from this link :
http://gdgt.com/toshiba/satellite/a305-s6857/specs/
Hope this helps you out.
Jul 13, 2009 | Computers & Internet
Dvd ram
Go to: http://gur.in/ then select "Registry Tweaks" in the left column, then select "Restore Missing CD Drive". This is the popular CDGONE patch. CD drives may vanish in Windows Explorer, Device Manager, etc. This patch and a reboot usually will restore the missing drives. Many Toshiba Satellite owners have had this problem and this fixes it! Also bookmark the page! This site has very useful info!
Nov 20, 2008 | Toshiba Satellite A135-S2386 Notebook
CD/DVD drive isn't recognized / cannot load driver
what is your operating system? have you upgraded yo a higher version? if you did then you must have installed a driver thatis not designed to work withy our OS now.
Apr 01, 2008 | Toshiba Satellite A75-S211 Notebook
Toshiba A105-S2051 Pioneer DVD-RAM DVR-K17 wont read discs
you just remove cdrom drive from your device manager and restart your nonebook
it will reinstall cd drive automatically
Mar 26, 2008 | Toshiba Satellite A105 Notebook
Sony VAIO VGN-SZ440 Notebook Logo
75 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
