Question about Kenmore 53642 / 53644 Side by Side Refrigerator
ICE Maker overflods
The water dispense is working OK. For the Ice Maker, When I lower the bar to the ON position, it overfolds.
  • 120 Answers
Usually they have a solenoid that turns the water off and on for a specific time period, if your lucky it is on the back of the machine connected to some wires you could try replacing it but it could still be the circuit board that controls that solenoid and if that's the case ( which it probably is ) it could be difficult to fix
Posted on Sep 24, 2008
    Genius:
  • 3,422 Answers
There are two basic issues that commonly cause an overfill condition. The first is an ice maker that is sending power to the water inlet valve for a period longer than eight seconds.T he power to the valve is being shut off in the correct amount of time, but due to imperfections in the valve, it is closing in a delayed fashion.
  • Priya darshan Sep 24, 2008
    How to Diagnosis:
    The
    easiest way to determine if your water inlet valve is the culprit, is
    to install a meter volt meter across the leads of the water inlet
    valve. Set the voltage range for 110v. Manually cycle the ice maker
    and watch the meter. When the ice maker begins to fill with water the
    meter will read voltage coming from the ice maker. Note the difference
    in time between when the voltage is cut from the valve and when the
    water quits filling the ice maker.
    If the water shuts off
    immediately when the voltage is removed, the valve is likely operating
    correctly. If this is the case, it is likely that the voltage will be
    applied to the valve for a period of time greater than eight seconds.
    This generally indicates an ice maker control problem.
    However,
    if the voltage is removed from the valve and it continues to fill, the
    valve is likely at fault. This indicates that due to particle build-up
    or mechanical failure the valve has lost its ability to shut
    immediately. in this case, simply replace the valve and it should fix
    your problem.
    In short it can be a dirty ice maker water valve or broken valve.
Fix icemaker
Start at the water valve at back of unit and work your way to the ice maker. Make sure the hose at the back of the frig isn't block. Also that the arm on the maker is down and in the on position. If all this checks, then go back to the solenoid that turns the water on and off to the ice marker.
Jan 03, 2015 | Refrigerators
Ice maker not making ice
Try raising and lowering the bar several times then make sure that the bar is in the lower position. If that doesn't work, you may have to replace the icemaker unit. You can find them at a supply house.
Aug 11, 2014 | GE Refrigerators
The ice maker stopped working, we have checked the water hose and their is water coming from the dispenser at the front of the door.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 29, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator 71203100 ice maker does not make ice. I get water from the water dispenser inside the refrigerator, but no water in the ice maker. The metal bar used to turn the ice maker on and off...
The water inlet switch on the back lower is always the problem. It has 2 solenoids, 1 for water and 1 for ice. They never go out at the same time. Follow the water line to the frige and there it is. Turn the water off repalace the part and plug the frige back in. check for leaks and enjoy...
Mar 29, 2010 | Kenmore Refrigerators
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
Ice maker stopped making ice
Hi
If the ice maker has completely stopped producing ice then check to see whether the ice maker has been turned off. For this you need to look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. If the ice maker is producing ice poorly i.e. if it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker made ice until we replace the water line to the fridge. Water dispenses out the door but no ice. Is it possible for the water to dispense out the door, but water not get to the ice maker?
Hi!
Pleae check to see whether the ice maker has been turned off. Here's how to check.
Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Thanks
Rylee
Jun 19, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker in Kitchen Aid stopped making ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Wont dispense ice or water
Hi
Please follow this :
Please revert for any assistance and Do accept this solution.
Thanks
Rylee
Mar 21, 2009 | GE Refrigerators
Ice maker won't quit dispensing ice cubes don't have ice skates!
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
Dec 11, 2008 | Amana Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
