Question about Nokia e65 Cellular Phone
Changing housing on Nokia E65
Hi. I'm trying to change the housing on my Nokia E65 and have read the the middle section is tricky to do but can't find any instructions how to do it. Can you help please?
John
  • Anonymous Oct 01, 2008
    I want to change the housing on my Nokia E65. Can not find any instructions how to do it. Please help!
Hi I have just changed my covers, it is in three parts front, middle and battery cover, first have a good look at your new parts to see where they clip, remove battery and sim, remove the front cover by unclipping it, remove the 4 screws on the back, on the front down the side of the lcd push and slide out the guide rails, watch the small rubber washers at the top and the plastic spacers at the bottom do not get lost, the front can gently be removed watch out for the spring catch that connects the front to the main frame and unclip from the post on the front, open the front just enough to gain access to the one remaining screw holding the middle section, unclip the circuit board at the bottom from the middle frame, prise out the connector bar along the side, watching nothing is catching your frame should come apart, I kept hold of everything in one hand while gently removing the mid section frame that way I did not have to disconnect any of the connectors, clip out the buttons from the side of the old mid section and replace in the new one, then work backwards to reassemble, I had never stripped a phone before but mine is now perfect with its new covers, just take your time and reason it out
cheers
andy
Posted on Oct 22, 2008
Hi shogun please call me glynhill35 on 07943231467 and i ll help you with the problem
Posted on Feb 14, 2011
HOW CAN I UNLOCK MY MOBILE E65
Hi, You can unlock a Nokia E65 safer and easier using unlock code. You can get the unlock code for a Nokia E65 from www.unlocking4u.com/nokia-e65/rs6wp9/ at affordable cost with easy unlocking instructions.
Sep 04, 2012 | Nokia e65 Cellular Phone
Nokia E65(memory full close some application or try again)
Change your Nokia E65 Message Memory.
for that you should go to message & go to options select settings there you'll find other select it in that you'll get memory in use default phone memory is selected change it to Memory card your problem will get resolved.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 18, 2011 | Nokia e65 Cellular Phone
Microphone nokia e65.
hi :) Mic pro that only a way can do,send for technician repair it. cause technical for changing mic cant do by own self.
Jul 07, 2010 | Nokia e65 Cellular Phone
I WANT TO CHANGE MY Housing Fascia Case Faceplate For Nokia E65 with keypad
Well you need to buy a faceplate or fascia for your Nokia E65. I receommend ebay. Looks like they are about 10 dollars for the set.
Check out the following link for a guide video guide and links showing what is available on ebay.
Change Faceplate on Nokia E65
Jan 20, 2010 | Nokia e65 Cellular Phone
How can i select the memory (nokia e65) as phone and not the memory card? i'm trying to increase font size of my nokia e65
use nokia pc suite to install the apps and there you can specify where you want to install it..
to change the memory selection for your msgs, you can go to menu>messages>options>settings>other>memory in use
there you can change this for your sms..
cheers..
Jun 16, 2009 | Nokia e65 Cellular Phone
Nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
Jun 15, 2009 | Nokia e65 Cellular Phone
Hi, I have a Nokia E65 phone and i am trying to enlarge the text on it, as i have trouble reading it as it is very small writing, is their any thing i can download to get this thankyou.
This is the best i can do for you Judy.
Look for PSILOC FONT MAGNIFIER and install it on your phone.
I hope you get through....
If you need help downloading and installing it, let me know.
Dec 02, 2008 | Nokia e65 Cellular Phone
Nokia
SLIDE THE PHONE UP. AT THE BACK OF THE LCD THERE IS A RECTANGULAR SHAPED STICKER,REMOVE IT AND SLIDE THE PHONE DOWN SLOWLY YOU WILL SEE THE SCREW.OPEN IT THRU THE OPENING THAT YOU SEE AFTER YOU HAVE REMOVED THE RECTANGULAR SHAPED BLACK STICKER.GOOD LUCK
Aug 19, 2008 | Nokia e65 Cellular Phone
Nokia 6300 mic problem
u just have damaged its earpiece and buzzer or u just forgot to move it from ur older middle section to the newer one
May 01, 2008 | Nokia 6300 Cellular Phone
E65 screen black out
try to check the sensor light on the upper left part and press it maybe its a little loose only....because i had the same problem a while ago and when i press the one connected to the sensor light.... a small brown board, it works properly...maybe yours is a little loose also....no need to pay try this one first....
Jan 29, 2008 | Nokia e65 Cellular Phone
Nokia e65 Cellular Phone Logo
2,763 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Prashant  Sharma
Prashant Sharma
