Question about LG WM2077CW Laundry XL Front Load Stackable Washer
Lg front load washer model wm2077cw
Hi
I have no power to the washer, tried the breaker, checked with a blender and there is power at the outlet. Could it be a plugged filter or something else no letting power to the machine. Left unplugged all night didn't make a difference
  • wendykost Sep 29, 2008
    Thanks, would you know where I could get a borad for the washer and instructions on how to replace it. Not sure if the top of the washer comes off or do you have to work on it from the back.
    Is there anywhere on the web that would show step by step instructions. My husband is mechanically inclined, but would require instruction.
    Thanks
    Thank you very much, would you know where the best place would be to purchase the board
  • 4 Answers
I had the same problem and all I did was drain the water from the front, clean the filter, and it worked.
Posted on Oct 05, 2009
  • 489 Answers
Your board has an built in fuse that cannot be replaced.  You will need to have the control board changed.
Posted on Sep 29, 2008
  • Richard Lew Sep 29, 2008
    Wendy,  the control board is accessed by removing the top panel.  There are 2 screws in the back that hold the panel in place.  Remove the screws and then slide the panel to the rear and remove the panel.  The control board is located in the left rear corner.  On the back side of the washer, you will find one screw holding the control board.  Remove the screw.  Now slide the control board to the right and lift up from it's mounting.  All the wires are simple connections and they cannot be crossed because of their color coding.  Be sure to order the correct control board.  LG goes by model and serial numbers to get you the right board.
    Good luck.
LG WM2077CW Front Load Washer Problem My LG Tromm model # WM2077CW is leaking at the bottom of the machine but not from the door. If you run your hand along the bottom front of the machine there is a seam...
MOST OF THE TIME IT IS A HOSE THAT HAS RUBBED A HOLE IN IT OR THE DOOR BOOT DRAIN HOLE. THE HOSE IS ATTACHED TO THE BOOT BOTTOM CENTER OF THE BOOT AND HAS A SHORT HOSE THAT RUNS BACK TO THE TUB..
Apr 25, 2017 | LG WM2077CW XL Front Load Stackable Washer...
Need link for manual for LG washer WM 1812 CW
You could download the manual from ;-
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WM1812CW-_E
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 30, 2009 | LG WM-1832C Front Load Washer
LG Tromm WM2277H washer won't start after tripping breaker
no fuses only control boards.with power off pull the top off and check wires at your power supply board(not the one with buttons). Look for burn or damaged wires. no luck with that, will probably need power board(usually the board that goes out). Call LG and speak to cust service....sometimes will cover the board.
Jun 11, 2009 | LG WM2277H Front Load Washer
LG WM2077CW small item trapped behind drum
you would need to remove bottom exit rubber pipe from drum and use a flash light to free coin or screw,hope this helps
May 27, 2009 | LG WM2077CW Laundry XL Front Load...
No power
No error code like PF Some times unplug for 2 hours.to 6hours for it to reset.
Jan 13, 2009 | LG WM-2277HW Front Load Washer
Whirlpool stackable washer
try unplugging from the power and starting again
Jul 30, 2008 | LG WM2077CW Laundry XL Front Load...
Start
that's not very helpful what you need to tell us is step by step so we know where and what to help you with sorry but it could be any thing??????????????????????????????????????????
Nov 18, 2007 | LG WM2077CW Laundry XL Front Load...
LG WM2077CW Laundry XL Front Load Stackable Washer Logo
716 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
