Question about Indesit Washing Machines
Indesit WM12x leaking water after wash & spin cycle
5 Suggested Answers
  • 209 Answers
SOURCE: indesit w113 washing machine
check heating element (rear of drum at the bottom) for open circuit, replace if needed, occasionally the timer will start to click round continuously, indicating the machine has a fault, the machine shuts down waiting for the water to heat up, elements available at most appliance shops but you may need to order specially?
Posted on Sep 02, 2007
SOURCE: Indesit Washing Machine WM12X... Were Should The
I have an Indesit WM12X. It seems to work sometimes and not other. So I set the program to 4 and its starts. It gets to the point where that water enters the drum then it seems to stutter and the dial just keeps on going round and round and the cycle does not progress. I switch it off and leave it for a while then switch back on. Sometimes the cycle restarts and completes and sometimes i have to repeat the process over and over until it works.
Posted on Mar 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: Indesit Washing Machine WG1103T Fills with water but doesn't spin
It appears your Pressure Switch or timer/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
  • 32 Answers
SOURCE: HELLO MY WASHING MACHINE WM12X
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Posted on Jun 10, 2011
  • 6277 Answers
SOURCE: hi ihave an indesit wm12x
This is symptomatic of a blocked drain filter/motor/pump.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 24, 2011
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
Jun 10, 2011 | Indesit W 123 Front Load Washer
Going through wash cycle but not spinning
my indesit starts to wash then comes up with 3 falshing lights and just keeps leting in water if i put the machine on with nothing in it it goes the wash until it gets to spin then starts to spin and agian starts letting in water
Mar 26, 2010 | Indesit W 123 Front Load Washer
Manual for intergrated indesit wm12x washing machine
To obtain the instructions for washer, go to,
WWW.INDESITSERVICE.CO.UK
In the menu on the left click on Indesit user manuals, then enter the model number in the search box, and down load the instructions to your printer or hard drive.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Indesit W 123 Front Load Washer
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Indesit Washing Machine WM12X... Were Should The Water Level Come 2 On A Wash Cycle..
The water level will never go above the lower part of the door bowl. Can you be a little more specific on your question?
Regards
Sussex Engineer
Oct 22, 2009 | Maytag MAH6500 Neptune Front Loading...
Indesit wm12x wont finish cycle just clix through dial,can u help me ?
i suspect that you may not be draining water,if you watch the light flash it will flash at 1 sec interviles it will then stop for approx 3 secs and then start flashing again at 1 sec int,if you wait for it to stop for aprox 3 secs.when it start flashing again count how many flashes til it stops again for the 3 sec,thats is your fault code,if it is 10 or 5,then its will be your pump blocked or inop.
Apr 05, 2009 | Indesit W 123 Front Load Washer
Help!! Indesit WM12X - cold wash only
Yes, they are easy enough to replace, but you need to test them with a multimeter to see if they are faulty..
There could be other things wrong.
Nov 22, 2008 | Indesit W 123 Front Load Washer
INDESIT WM12X
brushes in your motor almost certainly, put your meter across the motor you will find a open circuit failinf that your control module could be damaged
Apr 21, 2007 | Indesit W 123 Front Load Washer
Washing Machine not draining
I have just fixed the same problem. At the front - bottom right is the filter - you may have to remove the kick board on your fitted kitchen to see this - put a small dish under to capture water - unscrew half a turn - drain off all the water - then fully unsrew and pull out - I had money and treads from jeans blocking the filter - clean out, replace filter and fully tighten. My machine worked after this. - Steve
Nov 21, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
