As television warms up the viewing screen reduces horizontally to a flat line. sound is fine. channel changing is fine.
  • 4,234 Answers
The set has a problem with the vertical circuit. Please update this with the make and model so I can provide you with details and further instructions.
Thanks,
Dan
Posted on Sep 24, 2008
Samsung flat screen T.V with sound problems.
Sounds like the issue is with the set top box of your cable or direct tv provider. Please swap that receiver for the equivalent or a more updated version.If the problem persists. Verify that all inputs on television is correct. It should match. Output of source( digital receiver,dvd player) to Input( television ). Make sure all is secure. Good luck
Jan 31, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Horizontal lines in the picture.
Give it time to warm up like another 10 to 15 mins i find put a tv guide channel on the screen stays pretty much the same picture, then leave the TV on" i use a 4 hour rule if i dont view in 4 hours or more i will close tv power
Oct 07, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
A horizontal line on the top of the tv when viewing some channels
that is normal, many tv's have this, just change the screen size, does this happen on hd channels too? or only regular channels?
Jan 21, 2009 | Vizio L32 32 in. LCD HDTV
Horizontal Lines when Viewing HD TV
Would you please change the picture mode 4:3 or scan fit to 16:9?
Nov 19, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Screen has green horizontal lines
could be the transformer due to the price you paid for the tv might be wothwhile having it replaced
Mar 19, 2008 | Philips 51PW9303 51" Rear Projection...
Noise and horizontal line
Very easy Fix, The problem is the cable box is not grounded properly. (not your fault) Go to the Local store and get a Plug adapter, just to change the TV plug that goes into the wall or surge protector from 3 to 2. Trust me on this....
Best regards
CircuitCity
Nov 29, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Lines across screen when using View On Demand channels
Could be a couple of things causing this.
1) Obvious, but I assume that you subscribe to these services, because otherwise it could be the encryption.
2) Make sure that you have the set-top box connected directly to the TV, and not through an external recorder (VCR, DVD etc)
This would be a problem if the services were copy protected in the same way DVDs are.
You could also check the settings on the set-topbox. Make sure the video output is set to RGB.
Aug 05, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
