Question about Black & Decker B2250 Bread Machine
The motor does not spin
I put ingredients in machine , set to "quick cycle" , the clock starts at 1:30 and counts down as it should. BUT nothing happens ,no movement at all. In the last part of the cycle the heating element turns on. The the machine stops.... and I am left with a blob of stuff...
Machine is 2 months old , used 3 times only.
Any Ideas ??
  • kasha100 Apr 23, 2009
    I have the same problem, I set the delay and it counted down but didnt go, now it wont go on any settings!
  • 21 Answers
This machine should still be under warranty, contact the store where you bought it to find out how to get it either replaced or fixed. Any attempts to fix this by anyone other than a certified repair person will void your warranty. Hope this helps you. Good luck!
Carol.
Posted on Apr 15, 2009
I received my breadmaker Christmas 2009. I have always used the basic setting but decided to make wheat bread. The recipe calls for a different setting. After I plugged it in, nothing happened; for...
Yes, many machines warm up a little when you choose the wheat setting, also if your manual shows the cycle times for the various programs you will probably notice a different Knead time (more) vs. the basic program and that is because whole wheat flour lacks enough gluten to make a nice, large, soft loaf, so to compensate it has a longer knead. Even with that though your whole wheat loaves are probably going to be shorter than a 100 whole wheat loaf.
Many bakers ( me included) add purchased wheat gluten and add that to the flour, (be sure to remove and equal amount of w. wheat flour from the recipe if you do this) to get a softer, higher, better texture loaf.
Feb 01, 2011 | Toastmaster Kitchen Appliances - Others
Washer is not spinning
either the pump is blocked or the belt has snapped
May 19, 2010 | Electrolux EIFLW55I Washer
Clock counts down but kneading does not start.
OMG, this just happened to me as well. It was trying to knee our Third loaf since buying it.
Glad to se it is not just us!
Scott
Mar 28, 2010 | Zojirushi BBCC-V20 Home Bakery Traditional...
The machine will start a cycle normally, but after the timer reaches a certain point it stops counting down and the machine will continue to agitate until you force it to stop.
Thank you for verifying the model type so many folks post non FAV6800A/FAV9800A questions in this forum machine specific topic area.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
You will need the Service Manual for support. I’m an owner like you with a solid repair skills on the machine and will try to help you DIY the repair if we can ID the issue through troubleshooting.
Do you have this condition in all wash cycles? Will a Quick Wash cycle complete? Do you see the Cycle Status LED ever indicate the machine has moved to the Spin Cycle during the wash cycle? This could be a Control Board failure but we need to troubleshoot.
I want to make sure the Wash basket will spin up with a Spin Only cycle selection. Can you select a Spin Only cycle with a empty wash basket. I would release the washer top so you can observe this test. I want to rule out a broken Clutch large wrap spring.
Page 33 of the Service Manual will show you how to release the washer top from the base. In Spin Only cycle raise the top just enough to make sure the wash basket is rotating Counter Clock Wise – CCW with the Spin Only cycle selected and operated.
If the above test doesn’t indicate an issue I would like you to try the Quick Service Cycle test on page 15 of the Service Manual and see if your FAV6800A will pass that test with no clothes in the washer. When you put the machine in Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00. Then press Wash/Rinse Temp to start Quick Service Cycle test. Did the test complete with a PA indication in the display? It will only display the PA code for a few seconds. End of cycle will beep washer will unlock and Cycle Status LED will indicate complete.
Waiting for your reply….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Spin Cycle
I just replaced my second motor control board because of the same problem. Mine starts to spin but never reaches speed and stops, then it repeats. It can do this for hours. I think we are overloading the machine washing area rugs. The fuses are OK on both failed boards and nothing is burned and all caps look normal. At $150 a pop, I would rather replace some components if I knew which ones. For a quick fix, the new board worked for me.
Aug 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Bread machine
sounds like a problem to me...in the mechanics of the thing..I'd take it back
Oct 20, 2008 | Black & Decker B2250 Bread Machine
Washer fills with water and thats it
Possible a bad motor control board. Depending on the age of the washer, you may need to replace the motor control board and the motor as a kit. Also be sure to test that the motor control board is getting power, I've seen cases of the motor/ motor control failing and taking out the main control also. The tech sheet is in the console and should walk you through the steps.
Jul 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer does not wash or spin
the electronic module who drives the motor its the problem . you can order and replace find part at partstore.com go by brand and model let me know if you need more help thanks
Jun 20, 2007 | GE WSXH208A Front Load Washer
Black & Decker B2250 Bread Machine Logo
123 people viewed this question
Top Black & Decker Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
Irene Tulloch
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
