Turn the key on.
Observe the odometer
Is it displaying ODO/total miles traveled? If not, depress the trip reset button until ODO is displayed
Key off
Press & hold the trip reset button, keep pressing it until advised to release it.
Key on
Observe the odometer display
you should see 5 dashes, then 4, then 3, then 2, then 1, and then 5 zeros, and then the mileage you started with.
Release the button.
You are done,
If you do NOT see 5 dashes, 4-3-2-1, set the trip meter to "trip 'A'"
and retry as instructed above. Some Toyotas use either method.
SOURCE: reset light
if it is the engine malfunction light your asking about (orange light)it can only be canceled by the main dealer or by removing the efi fuse (located in fuse box on rh side of engine bay near the battery) for 60 seconds while car is not running,light may come back on again if a fault reoccurs
SOURCE: Toyota Yaris abs and brake
abs and brake lights on is a warning that your car has some issues related to the braking system. fix it first.
SOURCE: Reset the maintenance required light on my 2008 toyota corolla
OK ON YOUR SPEEDOMETER, THERES TRIP A, TRIP B, AND THE REGULAR ODMO... U NEED TO PUT IT ON TRIP A (WITH THE KEY OFF) ONCE U GET IN ON TRIP A, PUSH AND HOLD THE BUTTON DOWN,WHILE HOLDING BUTTON DOWN TURN KEY ON, YOU WILL SEE LINES POP UP ON THE ODOMETER, (WHERE THE MILES ARE DISPLAYED) THEY WILL GO OUT ONE BY ONE, ONCE IT STATES 0 YOU ARE GOOD TO GO.. GOOD LUCK AND THANK YOU FOR USE FIXYA.COM..KEITH..
SOURCE: toyota yaris brakes how do you bleed the brakes on a toyota yaris
have someone pump the pedal and hold it, then you work from the right rear, left rear, right front, left front, while the person pumps and holds several times at each wheel.
SOURCE: Toyota Yaris 2009 Clock Reset
Check your owner's manual. Then try the other button? This is a new car, though. Try disconnecting the negative battery terminal for about 15-minutes to reset 'all'.
I have paired my alcatel phone with my Yaris, but when calls come through the screen doesnt show whos calling and pressing the knob on the steeringwheel makes know difference
