My printer is not working i need a driver install
  • 57 Answers
Check with your Manfuacture of your printer, at their web site you can download the drivers.
Posted on Sep 24, 2008
    Master:
  • 479 Answers
For printer drivers
just click the link below and enter the approtiate model number of ur printer and download drivers.
www.lostmydrivers.com
Trying to install printer
You should have install the printer driver on your pc before paired them in the first time. This is to make sure your printer can work smoothly on your PC/OS. Otherwise your OS will run its standard driver ( sometime this standard driver will not work perfectly for your printer, especially for uncommon printer brands ).
So, again for best result you need to install its original driver ( it usually bundled on printer box while you bought).
regards
Sep 16, 2011 | Computers & Internet
Error message from printer properties : Can not print test page. This operation can not be completed. Take note that printer self-test is working and from printing option cleaning cartrige work perfectly....
You need first to do the following:
Check first a different usb cable ( be the case).
Check that the printer is the default printer or you are not printing to a different printer installed in windows
Do driver setup procedure.
Disconnect printer from usb.
Go to 'installed printers' and remove the printer from windows (right click and delete). If you have documents in printer cue you may need to purge documents in cue.
Restart computer (printer disconnected).
Re-install drivers from disk (printer disconnected).
Only connect printer to usb when required by printer install software or after installing software.
If the above did not work the printer can be faulty, in this case usually it shows some dignostic message, like flashing red light etc.
Check also that is not a windows problem, by installing in on a different computer (get a laptop) and printing a test page.
Regards
Apr 15, 2008 | Office Equipment & Supplies
The driver will not install
Instead of allowing the driver to install automatically when you plug in the printer, find the actual driver from the web, download it, and install it. Some companies include printer instillation in their drivers but some don't. If you still need to install the printer after installing the driver, follow these steps:
1. Click Start, click Control Panel, click Printers and Other Hardware, and then click Printers and Faxes.
2. Double-click Add Printer to start the Add Printer Wizard, and then click Next.
3. Click Local printer, clear the Automatically detect and install check box, and then click Next.
4. Click next.
5. Click Have Disk and find the drivers you just installed.
6. Click next until the setup wizard is complete.
7. Make sure to print a test page. If it works you're all good, if it doesn't try making sure you're using the right drivers and come back here if you need additional help.
You can find the drivers for your printer here:
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-D92-Printer/Drivers-Support;jsessionid=42CB17292574985A9FCC0A1D32049747.acc6-new
Apr 10, 2011 | Epson Stylus D92 InkJet Photo Printer
Problem in installing printer driver
you need to install your printer driver and make sure that your installed the correct driver for the operating system the you are using.
May 04, 2010 | Lenovo 3000 Y410 Laptop
How Can i install my printer on my laptop without the disc.
let me know the exact operation system you are using ...and the name and number of the printer ...I will link you to download a driver for them to work together
Dec 17, 2009 | Cameras
Printer does not print
Did you install the proper drivers ?
Sep 13, 2009 | HP DeskJet 3820 InkJet Printer
I have had this printer for about 2 years or so. It used to work. Now it gets frozen on the USB printer port page when I try to print. So I went to the dell printer driver page and downloaded the printer...
no need new printer first uninstall old printer drivers from computer then check your printer model number and download exact driver again then install.
Jul 13, 2009 | Dell 725 InkJet Printer
I cannot find a printer to work on Acer Aspire X3200 Vista
any printer will work in your PC...as long as your computer meet the minimum requirement for the printer u choose
before you install the driver..remove or Un install the other program and driver you installed earlier
and restart the PC
you must install the right driver...install the driver that compatible to your Operating System (Xp, Vista), when installing the printer select the right port where you connect your printer (USB, LPT).
they are some installation instruction that you need to install the Printer Driver and Utilities first...then connect the printer or Restart the PC and connect the printer....
goodluck
Mar 16, 2009 | Computers & Internet
Cant get my printer to work on my newHP computer
If you have Vista, old printers may not work.
You need to install the driver first, if you have the disk run the driver setup from CD, otherwise do the following:
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading, find thefile,double click on the file, then if you get introubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista
Oct 15, 2008 | Lexmark Office Equipment & Supplies
Installin hp 9130 all in one without install cd
Contact hp & order a CD
If the download was not working this would be fastest & easiest solution.
What is your operating system?
Dec 06, 2007 | HP Officejet 9110 All-In-One InkJet...
jasbo
jasbo
