Question about Sony KP-48V90 TV
No picture the picture turns off and timer/stand by indicator flasher two times
  • karen316 Jan 19, 2009
    No my problem, is that it blinks 5 times, pops up Video 4, and sometimes the picture blinks out also. What does this mean?
  • daisydiane15 Mar 22, 2009
    I have a sony modle#KP-4890, when I turn it on there is no picture at all, but there is sound. any ideas?
  • 10,594 Answers
2 times flash shows problem in +B volt supply and possibly have some short circuit in horizontal area. There can be few parts damaged and need to be replaced.
If you know how to repair tv, I will provide you more technical information. If you don't have electronics knowledge, please contact nearest Sony service center.
Posted on Sep 24, 2008
My stereo keeps turning off when I listen to a station 101.5 in New Jersey
The only thing that can be is that you have set a timer "sleep" function for that station. I have looked at the manual and it states you can programme a sleep setting for a radio station.
The instructions are on page 12. But I have extracted them below:
1 Press the ON/STAND-BY button to turn the power on.
2 Press and hold the CLOCK/TIMER button.
3 Within 10 seconds, press the or button
to select "ONCE" or "DAILY", and press the MEMORY
button. Set the clock to the correct time if "ONCE" or
"DAILY" does not appear.
4 Within 10 seconds, press the or button to select
"ONCE SET" or "DAILY SET", and press the MEMORY
button.
5 To adjust the hour, press the or button and then
press the MEMORY button.
6 To adjust the minutes, press the or button and
then press the MEMORY button.
7 Set the time to fi nish as in steps 5 and 6 above.
8 To select the timer playback source (CD, TUNER, USB,
iPhone/iPod, TAPE or AUDIO IN), press the or
button. Press the MEMORY button.
When you select the tuner, select a station by pressing
the or button, and then press the MEMORY
button. If a station has not been programmed, "NO
PRESET" will be displayed and timer setting will be
canceled.
9 Adjust the volume using the VOLUME control, and then
press the MEMORY button. Do not turn the volume up
too high.
10 Press the ON/STAND-BY button to enter the power
stand-by mode. The "TIMER" indicator lights up and
the unit is ready for timer playback.
11 When the preset time is reached, playback will start.
The volume will increase gradually until it reaches the
preset volume. The "?" or "DAILY" indicator will blink
during timer playback.
12 When the timer end time is reached, the system will
enter the power stand-by mode automatically.
Once timer:
The timer will be canceled.
Daily timer:
The timer operates at the same time every day. It
will continue until the daily timer setting is canceled.
Cancel the daily timer when it is not in use.
Jan 06, 2016 | Sharp CD-DH950 5-Disc Compact Stereo...
Our Trinitron KD-27FS170 Tv will not turn on. It sounds like it is turning on/off but no picture or sound. The Stand-by/Timer red light is flashing 4 times, pause, then 4 times, etc.
This typically means you have a bad capacitor, you can inspect for any swollen or bulging capacitors however unless familiar with desoldering boards best leave it to a repair technician.
Jan 13, 2015 | Sony FD Trinitron WEGA KD-27FS170 TV
TV will not power on. prog timer flashers
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 28, 2010 | Mitsubishi CS-35305 TV
Both my turn signals and emergency flashers stopped working
hi...
there is a relay which connects turn indicator and the emergency flashers which is provided for the timing of the flash.this timer relay may got burnt or damaged. even though the fuses are OK the turn indicators wont work. please check this.
please rate me weather the information which i provided was usefukll to you by clicking on the thumbs present on the end of your page.thank you
Jul 09, 2010 | 1999 Ford F350 Regular Cab
I want to know the functions to all buttons for
This is a car question.
I believe you are asking about the S-(shift) indicator button. A button with a pyramid is your emergency flashers.
A shift indicator button turns on the shift light when you are shifting the car to help you shift at the right time.
A flasher button turns on the four way flashers.
A better idea is to provide the model of the car, Auto or manual transmission and it year. A picture of the interior of the car could help, showing the buttons. This will help a lot. Thanks!
Mar 22, 2010 | Car Audio & Video
Wont power up 2004 tv
this indicates a power suppy fault,there are power supply kits you can buy which will clar most faults like this but if you hav ever done it before i wouldnt, you can geta mssive shock even though the t.v is off also you could ruin it beyond econoical repair take to a t.v. engineer, please lave feedback
Jul 20, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Tv turns on then off, stand by timer light blinks 4 times
You need to replace the power supply unit on this as it has malfuctioned there about $90 bucks plus labor on that.
May 25, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Location of flasher for turn signal
  1. Access the COMBINATION Turn Signal and Hazard INDICATOR FLASHER on the Left-Hand (drivers) side of the instrument panel in the fuse junction panel.
  1. Remove turn signal flasher/hazard indicator flasher by pulling indicator flasher straight out.
  1. To install, align the terminals of the flasher and press into place.
How about a picture--
Oct 03, 2008 | 1996 Ford Thunderbird LX
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
Tv wont turn on
How many times does the light flash, as there is a code that can give an indication as to what circuit is bad.
Jul 15, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KP-48V90 TV Logo
94 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
