Question about Microsoft Excel for PC
I want to link a word document to a cell in Excel
  • 38 Answers
Dear nshrivas,
Type some text in a cell and select that cell then right click choose Hyperlink option then select the file which you want to link and click ok.....
Thanks,
Posted on Sep 25, 2008
Excel 2007 document recovery repeating document on Terminal Server
MS Excel File can get corrupted due to virus attack, missing MS office files, power failure and other possible reason that can be fixed by only use Stellar Phoenix Excel Recovery fix corrupt Excel (.XLS/.XLSX) files and restore everything (including charts, chartsheets, cell comments, worksheet properties etc.
Jan 04, 2015 | Microsoft Excel for PC
Hyperlink other document in excel button
The easy way (but labor intensive) is to put the file names in a column (can be any name you want or the pdf file name), right click on a cell, hit insert hyperlink, and in the address field at bottom, put in the file pdf file name. You would have to do this for each of your 100 files.
If you want to automate it, create a column with the directory path name, a 2nd column with the full file names, a 3rd column where you concatenate the two previous columns to create the full path, and then use the hyperlink command to provide the link:
Folder name Filename Concatenated LINK ../excel/ file1.pdf ../excel/file1.pdf file1.pdf ../excel/ file2.pdf ../excel/file2.pdf file2.pdf ../excel/ file3.pdf ../excel/file3.pdf file3.pdf
Here are the formulas behind this:
A B C D Folder name Filename Concatenated LINK ../excel/ file1.pdf =CONCATENATE(A2,B2) =HYPERLINK((C2),B2)
../excel/ file2.pdf =CONCATENATE(A3,B3) =HYPERLINK((C3),B3)
../excel/ file3.pdf =CONCATENATE(A4,B4) =HYPERLINK((C4),B4)
This should work like a charm and the other advantage is that excel won't rename your path locally depending on weather a file is open or not).
Feb 21, 2014 | Microsoft Excel for PC
Excel table link in word
Excel and Word are two parts of the Microsoft Office Suite that have become standards tools for spreadsheets and word processing.
Among their features are the ability to easily exchange information.
For example, you can easily copy a cell or part of a spreadsheet from an Excel and paste it into a Word document, which preserves all the formatting.
This method requires opening up both programs at the same time.
To avoid this, you can insert an Excel file from within Word itself.
Choose the "Insert" tab inside Microsoft Word to display the Object dialog box.
Click the "Create from File" tab and Browse to display the Browse dialog box.
Navigate to the Excel file that you need and double-click to load its name into the File Name box of the Object dialog box.
Click a checkmark into the "Link to File" box if you want the table that you insert to be automatically updated anytime the original file is changed.
Otherwise, leave it blank if you don't want the inserted information to be affected by the original file.
Click "OK" to insert the Excel file as a frame into the document.
Note how only filled cells from the first table (worksheet) of the file are inserted.
Blank cells are not inserted. You can resize the frame by clicking it and dragging the handles that appear.
You can also click it and drag it to a different line within the document.
http://office.microsoft.com/en-us/word-help/link-or-embed-an-excel-worksheet-HA010120810.aspx - BM4
Aug 07, 2013 | Microsoft Excel Computers & Internet
Excel to word tables linking
Aug 07, 2013 | Microsoft OFFICE 2013 HOME AND BUSINESS 1...
How to use document viewer in samsung star wifi
document viewer, can be use to view documents such as word, excel, or text notes (notepads). if you received a files containing excel or word, then you can use this to view it.
regards.
Mar 03, 2010 | Samsung Star GT-S5233 Cell Phone
How do you print envelopes?
More information is required so I will only assume you are using Excel as a database. Excel is a spread sheet program used by accountants or for mathematical formulas and ledgers. Access is the Database program, however, Excel has functions which is faster to sort and work with address, phone number, zip codes. I will confess, I use Excel as Database because it is quick and easy. I do not know what version of Excel you are using so I will describe it from Office 2007. From Excel make sure you have headers above each column i.e. First Name in Cell A1 Last Name in Cell B1 Address in Cell C1 ect.
Make sure your data is correct and case sensitive as you would like it. If you want zip+4 select the Colum and right click to format the cells using special and select Zip or Zip+4.
It is easiest to use Microsoft Word for the next step rather than format the cells, add page breaks, and customize the print size.
Save your document as an Excel document where you can find it to import it into Word.
Open word and select Mailings then Start Mail Merge and Step by Step Mail Merge.
Select Envelope and next. Select envelope options to change envelope size, font and print options.
Click on Next Select recipients.
Click on browse under select an existing list.
Select the Excel file with your address information.
From the Select Table check the First row of data contains column headers.
Click on the OK buton.
Arrange your envelope then Preview it and your good to go.
If you have an older version of word selects Tools and click on Mail Merge.
Select Get Data.
Pull down Excel for document type.
Select entire Spread Sheet.
Layout your document and complete the merge.
On old versions of word it may not recognize the Excel file. If this happens open the Excel file and save it as a Database File (.dbf) and it should work.
I hope this helps since I did not have enough information from your question.
Jul 15, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Link in excel 2007
right click on any cell then select hyperlink option from the list then a dialog box will appear infront of you
in left hand side pane there is option place in this document click on that then in right hand side pane select sheet 2 or sheet 3 whichever you want...
or if you want to open any other file so use existing file...option
Jul 01, 2009 | Computers & Internet
Deleting file from Excel also from recently created documents.
Hi jv_oberg,
The recent documents area of excel is just a snapshot of what it last opened, it's not really linked that document to excel. Eventually, after you open enough documents it will fall off the list. However, if it something that you would like to change, you can
  1. Click on Office button, and then click on Word Options (in Word 2007) or Excel Options (in Excel 2007) or PowerPoint Options (in PowerPoint 2007) in the bottom of Office Menu.
  2. Go to the Advanced tab.
  3. Scroll down to the Display section.
  4. Set the value for Show this number of Recent Documents: to 0 (zero). no-of-recent-docs.jpg
  5. Click OK button.
  6. Repeat steps above again, and set back the value for the number of Recent Documents to show to its original default, i.e. 17. If you don’t want this particular Office 2007 application to remember any Recent Documents, you can leave the value at 0 and skip this step.
That will clear your recent documents.
Good Luck,
Mark
Don't forget to leave a rating!
Thanks
Jan 06, 2009 | Computers & Internet
VISUAL BASIC TOOL LIKE SCROLL BAR, COMBO BOX US IN EXCEL
hello
You can make a link into cell that you want by right mouse click
Heperlink, link to , place in thins document , on the feild type the cell reference (A22 ,E56) ...etc , & link where is the cell that you want link to . & in which sheet it is .
i hope good luck
Jan 10, 2008 | Computers & Internet
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
48 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
