I have found that replacing the carb. with a new one . Usually between 27.00 to 38.00 dollars usually saves a lot of time over installing a kit. problem is usually due to a jet problem or the ethanol in the gas has removed the coating on a plug inside the carb. which requires carb. replacement
You did not indicate whether or not you have compression now that you have changed out the gaskets and piston rings. If not, it seems to me that the problem could be a) cracked head or block, b) bad valve(s) or even c) a warped head.
Usually when purchasing a new Carb, they are set very close. No adjustment needed. But if you want to play, turn both the High and Low screws all the way in then turn them bot out about 1.5 turns. that should get it started. The you will need to tweak the High sped and then the low speed and then the Idle
The vent is not working properly or was installed incorrectly, so there is no negative air entering the tank to take up the space of the fuel leaving it for the combustion chamber. Perhaps your tank cap has a vent as well that isn't working.
If there is good fuel in the tank and the plug gets wet with fuel, and there is a good spark stating the obvious it should go, if not there could be a mechanical issue, piston scored, rings worn etc,
