Question about Hayward Heatpro 100,000 Digi. Thermostat Heat Pump
Hayward Heat Pro Electric won't stay running
I have a 4-year old Hayward HeatPro electric heat pump. The pilot light will come on and stays on with power and the thermostat is turned up full. Sometimes when I flip the breakers on, the heat pump will start and shut off in 5 seconds. Left this way, later it will start again by itself and go off again in 5 seconds. Ever since I put this unit in, it seemed erratic, in that sometimes it would start right away and other times it would start when it was good and ready (mentioned just in case it give a clue). Now it won't heat at all!
I do not see a model number on it but it is about 40 inches tall and 32 inches in diameter.
I see questions and answers about self-diagnostics and digital this-and-that, but I don't think I have that kind of unit. If I do, I need that help.
Thanks in advance.
  • Dale Charles Oct 03, 2008
    I have good flow from the pump as determined by the 6 spa jets pressure, but am wondering if there is an internal or external flow sensor that is faulty? I know there is a flow switch on the pump/salt system, but this seems independent of the HeatPro unit. On the front of the HeatPro is a 5-inch round device in the return line that has a clear plastic cover. I can see some mechansim inside, but there is no wiring going to it, so it must be just mechanical.
    There is a hayward manual on this heat pump, but evertime I try to download the pdf file, my computer freezes. Don't know if there is more info in the manual that can help me or not!
    Thanks.
  • Dale Charles Mar 09, 2009
    As it turned out, there was a leak in the steel tubing and the gas leaked out! The unit is 4 years old and Hayward immediately had a local serviceman respond and fix the problem. I never saw a bill of any kind. I am pleased with Hayward's warranty, but it seems I have lots of problems with this system: pump, motor, DE filter, heat pump, thermostat and some other connectors and fittings.
    Don't know if there is a better system out there or not! I am concerned about lots more problems in the coming months after the 5-year warranty is over!
From the Hayward support site....
Why is my pump cutting off and on every 5-10 seconds?
  • Hayward motors are factory wired for 240 volts unless the motor is 120 volts ONLY. Check the voltage of the incoming supply power and ensure the motor is wired or can be wired for this voltage (data plate on motor will help provide voltage and wiring information). Also check for loose or badly connected wires. Contact a certified electrician for repair.
Posted on Mar 08, 2009
  • AQUAMAN2000 Sep 09, 2011
    from WaterColors Contracting Co. [pool pros]
    Prob:Solution: Your problem stemmed from low R22 causing a low pressure reading in the coil pressure sensor. Unit will short cycle if slightly low and will completely take itself off line if very low. You should have gotten an "LP" error code, while this was occuring.
    Advice: Answering your question about whether or not there is a better system available? Answer is not really. Systems equipped with automatted controls and chlorinators, heat pumps, auto pool cleaners are complex. They are doing a lot of things under adverse outdoor conditions. They require regular routine maintenance to keep them running optimally. Our suggestion is to find a competent service company that can maintain such a system once per week in the swimming season and somewhat less frequently in the off season. If you live where temperatures go below the freezing mark. Make sure a service company "Winterizes" your system ! AND have that same company 'Contracted" to open your pool in the Spring. Believe me, this is money well spent. With the right company you will enjoy your investment much more.
    Coastal North Carolina call 910-457-9145
Hayward heatpro running but not heating. The "run" light is yellow but it should be green
i have found nothing in any of my heater manuals to account for the color of the light. in every instance, the light is either lit or not. the color does not change.
as for the not heating, if the outside temperature is less than 60 degrees, your heat pump will not work well. as heat pumps do not heat water very efficiently, there may not be a noticeable difference in water temp. the best way is to measure the temperature going into the pump (outside ambient temperature) and the temperature of the air exiting the top of the heater.
if the outside temp is 70 and the air out of the heater is 65, there is a 5 degree temperature applied to the pool water. this can be diminished due to transfer of heat to system
Jun 09, 2015 | Hayward 116k BTU HeatPro Digital Heat Pump...
How to change the pressure switch on HeatPro Heat pump
this requires a torch and lots of heat , if your not 100% familiar with this equipment then consult a profesional for assistance
Nov 01, 2014 | Hayward HP11003 HeatPro Heat Pump 112000...
Error Code E-08 on Samsung Gas Range. Oven will not heat but range top works.
Is there a gas pilot light that stays lit all the time or does it have an electric pilot light that glows red to start the oven.Either way if it's a gas pilot the thermocouple is bad, if electric the igniter is bad.
Jan 03, 2014 | Samsung Kitchen Ranges
I have a HP 1002. Makes a
This is your contactor enguaging and one of those things you don't notice when everything is working. At this point your getting power through the unit and will need a pro to probally replace your element.
Aug 05, 2009 | Water Warehouse Hayward HeatPro In-ground...
Hayward HeatPro Heat Pump for pool won't turn on
Power to the unit but not the display + mice = bad board probably. Service call required...
May 27, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Hayward pool heater - p5 code
The code is "PS" for Pressure Switch and means there is insufficient pressure to operate (low flow) or the switch itself is bad.
May 26, 2009 | Hayward 116k HeatPro Heat Pump HP3100
Hayward pool heater wont stay lit
Follow the troubleshooting guide on page 36 of this owners manual. It will walk you through problem solving... http://www.haywardnet.com/products/Manuals/pdfs/Manual285.pdf
May 25, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Heat pump will not start
Could be a firmware issue and require a new mother board. Unfortunately, you probably have done all you can on your own. Time to call the local HVAC service person...
May 03, 2009 | Hayward Heatpro 81k Btu Swimming Pool Heat...
Corrosion on the fins of my heat pump
Do you have something close to it like a hot tub or spa or pool? If so the Chlorine is reacting with the aluminum causing it to corrode.
I suggest moving one or the other if this is the case.
If this helps you please rate me as high as you can If not please post back with an extended detail of your problem. thank you for using fix ya. Good Luck.
Nov 13, 2008 | Hayward Heatpro 100,000 Digi. Thermostat...
Hayward Heatpro 100,000 Digi. Thermostat Heat Pump Logo
480 people viewed this question
Top Hayward Garden Experts
Craig Butler
Craig Butler
Bill Boyd
Pushkar Singh
Pushkar Singh
Level 1 Expert
Are you a Hayward Garden Expert? Answer questions, earn points and help others
