Question about Malber WD1000 Front Load Washer/Dryer
Dryer won't dry
The wash cycle completes and the clothes are not dripping. then when the dryer cycle goes on, the drum spins but the clothes are just as wet. we use one tablespoon of liquid detergent.
Www.malberusa.com
61 Commercial Ave
Garden City, NY 11530
(516) 294-6660
first empty the waste container on the right buttom of your machine you have to empty that container every couple of washes.if not solved replace the heating element. the tel # above.
good luck
Hadi
Posted on Oct 01, 2008
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
Clothes are still wet after last spin cylce
Most washing machines do not dry the clothes completely. Make sure that your clothes are evenly spaced & the weight is balanced to get the best spin speed. When the cycle is complete, you will need to put the clothes into a dryer or hang them up to get them completely dry.
Aug 30, 2015 | Washing Machines
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire FGX831CS Top Load Stacked...
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
Washing cycle just fine, goes through the spin cycle, but clothes are not spun out, still dripping wet, but water has drained. Replaced the timer but still does not spin out.
The belt around the drum may be worn and slipping, either on the drum or motor.
Check to see if you can find any evidence of belt dust, etc.
Mar 17, 2011 | Washing Machines
How do you dry on this machine? if you dry on the green, does it completely dry?
The automatic preheat and drying cycle kicks in as the final wash spin is under- way. The system employs a condenser dryer in which the hot air used to dry the clothes is channeled into a drum, instead of being released into the great outdoors via a dry vent hose. Cold water is drawn into the drum at the same time. The two mix, and the result is a condensing process.
The chlothes should be dry. there may be a damp feeling to them but otherwise dry. If your machine is not drying then the element could be going bad, or a thermal cutoff. those would be the easyiest fixes.
The BIG drawback is drying. It takes about 90 minutes to dry a load, and the clothes come out very wrinkled. Because the drum is so small, the clothes don't 'toss' in heated air and don't fluff at all. Clothes also come out stiffer than a regular dryer.
Jan 06, 2011 | Equator EZ 1500 Front Load Washer / Dryer
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
200 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
