Question about Craig 731398403288
DISC STUCK i put a cd disc by mistake.now i can not open.i can't even off the dvd player by remote control.can please advise me to take out the disc. i have CRAIG DVD PLAYER.THANK YOU
It should not matter if it is a DVD or CD, because the CRAIG CVD327 palys both. It must be some other problem. Also, use the button and not the remote.
Posted on Mar 02, 2009
Dvd stuck in home 7-cd/dvd changer
So you want to remove the disc without damaging the disc? so its ok to damage the player.
Put a cushion on the floor, put player on it.
Use a strong pair of pliers to crush and bend all the plastic parts of the loader near the disc, shake the player so that the disc falls onto the cushion.
Dec 21, 2013 | JVC Audio Players & Recorders
Philips DVD recorder, (250gb) DVDR3460H. can not remove disk .........
your gonna have to open the machine up the there is a whits tab that lifts the disc up to spin you will have to use your fingers to slde it of that make sure its unplugged and then the white thing will realese
Sep 19, 2008 | Televison & Video
I have a panasonic dvd/cd player (model NVVP31EBEBL) and i can't remove the dvd disc! any ideas, please?
You mean the disc is stuck inside the player? if that is the case try first turning off the player then turn it bck on and see if you can take teh disc out.
If not you may need to open the player to take the disc out because this can be a mechanical problem or the disc is broken or something..
Hope that helps.........
Aug 05, 2008 | Televison & Video
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
Philips dvd player remote control, by mistake started password
Try using the password 136900. If this works for you, then using your remote, access the general setup menu and choose the Disc Unlock option.
Hope this helps!!
Jan 24, 2010 | Philips DVP3962 DVD Player
The disk in m y wii is stcu and wont come out,
  1. Make sure you put the Disc in the Console and not in your DVD player as I had. Easy enough mistake when putting the Disc in and you are so use to putting it in the player.
Dec 29, 2009 | Nintendo Wii Console
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
How do you put on a dvd?!
i take it all set up the dvd to tv.?
turn on the dvd player with the remote .
press open on the remote
insert the disc dvd out of the box
close tray
press play to watch dvd
when finished
press open take out disc and close disc tray and turn off dvd player .
riz.
May 24, 2008 | ASUS DRW-1608P2S DVD RW Dual Layer Burner
Craig 731398403288 Logo
157 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
