Question about HP OfficeJet 7410 All-In-One InkJet Printer
Prints in staggered columns
Our hp 7410 officejet printer prints in staggered vertical columns. Everthing is not aligned. Alignment test passed. Will print fine if copying only. Print from computer or faxes coming in, not good.
    Scholar:
  • 137 Answers
What you describe is typically caused by ink aerosol building up on the encoder strip, a thin band of plastic that the printer uses to keep track of its location.
You can gently clean the encoder strip as shown at HP's website here. Be sure to heed to cautions and notes. Do not use any solvents other than water and be gentle to avoid damaging the encoder.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Oct 02, 2008
Vertical alignment
Usually this is asked when the printer is using more than one page of paper to print what the word processor shows as 1 page. This is fixed in the word processor program print set up module that opens when you click Print.
If you really want to change the vertical alignment of the print heads, then you need a different printer.
Feb 28, 2015 | HP OfficeJet 6210 All-In-One InkJet...
Vertical lines are not smooth, they are jagged. The lines are straight for about an inch, then they are offset to the left. Some words are broken in half horiziontally with the lower half offset to the...
You can align the print cartridges at any time from the control panel or by using the HP Image Zone software on your computer. Aligning the print cartridges ensures high-quality output.
Note: If you remove and reinstall the same print cartridge, the HP all-in-one will not prompt you to align the print cartridges. The HP all-in-one remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges.
To align the cartridges from the control panel:
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Press Setup.
  3. Press 6, then press 2.
  4. This displays the Tools menu and then selects Align Print Cartridge.
  5. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges.
Feb 16, 2011 | HP OfficeJet 7410 All-In-One InkJet...
My hp officejet 7410 printer which has been working fine for a year suddenly will not print. after putting in new cartridges it printed out an alignment page. But still will not print a normal page. ...
Click on the Setup button,
Scroll till you find Tools - Press OK
Scroll till you find Clean Cartridge - Press OK
It will print an alignment sheet. Align the printer
If this does not work - try the Align Printer Option from Tools of Setup menu again from Printer front panel.
Let me know if none of these work.
Regards,
Shawn
Jan 31, 2011 | HP OfficeJet 7410 All-In-One InkJet...
HP 7140xi comes up with alignment failed after replacing black pr
you could try by passing the alignment
Press and hold Setup and then press OK simultaneously when align message is prompted on the All-in-One.
Jan 27, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Some of the prined lines are being cut off at the bottom
Try to realign the printhead.
  1. Make sure the printer is loaded with unused white paper.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
If that does not work you can try changing the ink cartridges and repeat the align process
Jan 19, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP officejet 7780
You must replace BOTH ink cartridges to get a sucessful alignment
Dec 18, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printing
The printer hp officejet v40xi is asking for a cartridge alignment. When I press enter the printer does nothing want take paper or engage the paper nothing
Aug 12, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Manual to repair
HP OfficeJet pro 8630 is out of alignment when you see the "alignment failed" message. Printer alignment web pages should be exact for obtaining accurate Prints.
Stay tuned regarding more updates, on boosting your HP printing activities. You can also visit our website 123.HP.com/ojpro and more guidelines will be provided to you for resolving the Printer alignment errors
To rectify the previously mentioned error:
    ·Try aligning your current HP OfficeJet pro 8630 ink cartridges by resetting the printer.
    ·You can also align, by using a diverse type of paper.
    ·If you have inserted fresh cartridges, it is the mandatory to check some alignment pages.
    ·This specific issue also occurs, if you have not tested the sample alignment page.
    ·This alignment web page checks the accuracy of the alignment settings. When your HP OfficeJet professional 8630 won't print, verify the leading cartridge access door.
    ·If this door is not closed properly, it could cause this issue.
    ·After checking the access door, decide if the alignment web page prints automatically.
    ·If it effectively prints, you can complete this process. If it doesn't print, search for the troubleshooting mechanism below.
    How to set the HEWLETT PACKARD OfficeJet pro 8630 print alignment issues by visiting our website 123-HP-com-ojpro. com
      ·Look into the printer carriage for any obstructions.
      ·The obstructions occur due to improper packing materials, improper position of cartridges etc.
      ·Try reinstalling the cartridges to ensure that the Printing process is accurate.
      ·Do not touch the nozzle, as this might damage your Printer.
      ·Tri-color cartridges can be slid into the left slot and the black or image cartridge has to be inserted into the right slot.
      ·A printer reset can solve this issue. Detach the Power cord from the printer device, without changing the printer system.
      Give a minimum holding out period of 30 seconds. We have a great team to provide you fantastic troubleshooting guidance or visit us all at 123-HP-com-ojpro. com or call us @ +1-855-718-4110.
Jun 04, 2008 | HP Photosmart 375 InkJet Printer
Printer cartrige question
Most hp printers print a alignment page when one of the cartridges is changed. If the other cartridge is empty, alignment fails, and printer will not work...
However for most printers is possible a procedure for bypassing a
alignment... if you tell me which printer you have !
Jan 12, 2008 | Office Equipment & Supplies
HP OfficeJet 7410 All-In-One InkJet Printer Logo
148 people viewed this question
Ben Johnson
