Question about Samsung CLX 3160fn All-In-One Printer
Replace/int tank toner error message
I have replaced the ink tank toner and I continue to get this message and it will not print
  • 161 Answers
If the toner bottle has been cleaned, it might still be dirty on the top. If the bottle is new, the you need to clean up the light sensors that pass through the toner bottle.
Be blessed.
Posted on Sep 29, 2008
What is error code -41
There doesn't appear to be any reliable information about an error 41 code for Canon inkjet machines. In a Brother machine it means a knackered printhead, but Canon has a different code for that. I can only suggest sending a message to Canon's web site/help desk to see if they can shed light on it.
Feb 12, 2015 | Canon Pixma MG5220 InkJet Printer
Xerox work centre 7328 giving error of replace black toner after guinue toner
If toner is new- check that it is in correct position- still printing fine? Error message continues, disregard msg- they are trying to sell you more ink
Apr 19, 2013 | Office Equipment & Supplies
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
My Lexmark X502n gives this error message: C Toner Empty Replace Toner C However its lying, the toner is not empty and if I open and close the front cover it then continues printing. This error message...
your lexmark toner is sticking if its a fill in and you filled in at store you can only use them so many times and the ink drys up in them replace cardlidges with new ones.
Feb 16, 2011 | Lexmark X502N All-In-One Laser Printer
I have the error message that it can not recognize the ink cartridge and it is blocking me from using the macine in any function. I have removed the ink cartrdige and it still says it cannot recognize...
An ink tank which has once been empty is
installed. Replace the applicable ink tank with
a new one.
Printing with a once-empty or refilled ink
tank can damage the print head.
If printing is continued without replacing the
refilled ink tank, press the Stop/Reset button
for 5 sec. or longer to record the use of a
refilled ink tank.
Oct 08, 2009 | Canon MP610 Photo All-In-One Printer
ERROR U130
The remaining ink level cannot be correctly detected. Replace the ink tank and close the Scanning Unit (Printer Cover). Printing with an ink tank that was once empty may damage the machine. If you want to continue printing in this condition, you need to release the function for detecting the remaining ink level. Press and hold the Stop/Reset button for at least 5 seconds, and then release it. * With this operation, releasing the function for detecting the remaining ink level is memorized. Please be advised that Canon shall not be liable for any machine malfunction or damage caused by refilled ink tanks. See “Replacing an Ink Tank” on page 46.
Apr 10, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
Samsung CLX 3160fn All-In-One Printer Logo
95 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
CheckitRight
CheckitRight
Paul King
Paul King
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
