Question about Crosley CW6000 Front Load Washer
No remote for Penney TV, so got One for All Remote. Can't program channels above 13.
I have a tv that I can only get up to channel 13 so I purchased a universal remote called OneForAll. I thought I would be able to get the upper channels but still only gray static. How do I program my Penney TV to view the upper channels?
  • letalou Oct 23, 2008
    I have model 4146 and use the One for All to turn on and off...but only get channel 13...and V1, V2 and V3 - none of them pick up the VCR signal...
I have a Crosley tv and a one for all remote that I would like to program so that it will work on my brand tv.
Posted on Oct 03, 2008
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
I am trying to get channels above 13. I do not
Try bringing up the menu by holding both volume buttons down at the same time (or use menu button on remote if you have it). Go into CH SET using the channel and volume buttons on the front of set (or use the SET + and - and the ENTER buttons on remote). Go to the TV CATV line and move the arrow to CATV. Let menu time out. This will put tv into cable mode. Hope this helps.
Mar 12, 2009 | Durabrand DU1901 TV
Unable to automatically scan for channels. menu button on remote does not work om my 1992 jc penney tv. No buttons on outside of tv except for the basic channel up/down and volume control. Recently...
To make it easy for you - you should have original remote.
Then through the menu look for channel set up then make sure you select cable or antenna then you do autosearch(sometimes called autoprogram).Unless the tuner is defective,you should be able to program withe the original remote.
Jul 19, 2008 | Televison & Video
Only stays on Channel 2 can't watch DVD's
hello, get a remote from key electronics.
info@key-electronics.co.uk
they will sell a remote to you if they have them in stock , ask about a manual too.
ive spents weeks trying to get help about our tv and wow at last we have some...
christine.....
May 01, 2008 | Disney DTD1363-CAR 13" TV/DVD
Zenith tv model #A32B41W
You probably need to get into the Menu > Tuner Setup and set it for "Cable" instead of "Off Air".
Hope that helps...
Geno
Mar 22, 2008 | Zenith B32A24Z 32" TV
Durabrand 13 inch tv
the remote need to clean pcb board ..... the chroma section pcb need to resolder loose parts such as resistor, capacitor or transistor that you may see on it.....
Feb 27, 2008 | Durabrand DWT1905 TV
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
Catv
try to purchase a new remote for samsung because all samsung remote is universal to all remote units.and there you can set the program.
Sep 04, 2007 | Samsung TV Remote Control
Remotes not working
well, sometimes the universal remote does not give you the whole functions, so it is better to work with the original one. you could fix it thought. here is how. most of the time, it just need cleaning. so get some denatured alcohol and clean the pc. do not apply any alcohol to the rubber button, that will ruin them. put it back together and give it a try again..good luck
Aug 01, 2006 | Orion STV2763 27" TV
Crosley CW6000 Front Load Washer Logo
67 people viewed this question
Top Crosley Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Karl H
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
