My router Netgear WGR614v5 is correctly installed and was operting properly and in conjunction with my 2nd computer wireless adapter netgear WG111T. Recently I lost all connections and re-installed everything back. Currently my adapter received a strong signal from my router but the mbps is only one and cannot connect to the internet or my printer. Need to know why my adapter is receiving a signal of 100% and the mbps transfer is so weak.
  • 1,879 Answers
Try changing channels (make sure you do it on both router & wireless card)
Posted on Sep 24, 2008
    Genius:
  • 1,124 Answers
It is the adapter on range?
What was a cause of lost connections? Virus?
Did you switch the adapters?
    Genius:
  • 1,550 Answers
Just have look over this link regarding the problem in your router
Router troubleshooting
SAM ANDERSON
  • 1,800 Answers
First try to reseting it
if not work
and double check the configrations
or maybe the wires are faulty and got too much ressitance in it.
best regards
  • 13,433 Answers
Hey,
lets start with installing the newest drivers available for the adapter and lets see how that goes, then we can try something else
http://kbserver.netgear.com/products/WG111T.asp
  • Ekse Sep 24, 2008
    make sure you first remove the old ones.. todo this
    start -> control panel -> add or remove programs. Find the drivers / software from the list, remove. install the new drivers from the webpage.
  • Ekse Sep 24, 2008
    Please let me know ones you have done this and what the results are. Thanks.
    Ekse
Netgear wg111t conection problem
  • log in to the netgear router's interface using www.routerlogin.com
  • username- admin , password : password
  • Click on wireless settings under setup . ( 3rd option from the top )
  • Under the security options .
  • U can find ur wep security passphrase to connect with netgear wireless.
In case of further assistance , do revert back
Feb 14, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Sep 14, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
I have a wireless netgear usb adapter and nothing else, its not installed on my computer and I want to put it on, it wont work, what do i need to get my usb wireless adapter to work??? It is a wg111t...
You first need to install the driver. You can download it here:
http://kbserver.netgear.com/products/wg111t.asp (it should have came with your adaptor)
You must also have a wireless router available for this to work, or in an area that has WiFi available.
Jul 17, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear 108 Mbps wireless usb 2.0 adapter wg111t
i had the same problem. i tryed downloading the sofware from other computer and install it on the wireless computer. finally i just connected it directly to a lan line and update drivers with windows
Apr 08, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
Netgear Wireless USB Adapter wg111t; installation
Hey there Kjantzi, I have found the site for Netgear, and as I read it the update is one of the options but the drivers and firmware are there as well. Check here:
Choose the version for your OS on the left, and it gives you detailed instructions, including the update process, if needed. If you still have problems let me know. Good Luck!
Mar 27, 2008 | NetGear WG111T 108 Mbps 802.11g Wireless...
WG111T config problems
http://kbserver.netgear.com/release_notes/d102803.asp
Download version 1.3
I was running into the same issue when I formatted my computer. It worked fine before that. I downloaded the version 1.3 though and it installed easily. There are step by step instructions how to install it as well. Hope this helps!
Jan 29, 2008 | NetGear WG111T 802.11g/b (E82321) Wireless...
WG111T
The solution I have is quite simple. I use Vista premium x64 so someone else can test it on Xp but it should work for both. In Vista the 1.3 version doesnt work so Facid's solution doesnt work for me.
[LIST=1]
[*]Get the 2.1 setup for Vista and install it.
[*]Go to your NETGEAR folder wherever you installed it to (Program Files x86 for me) and copy the DRIVERS folder to your desktop.
[*]Uninstall the smartwizard and remove everything in the NETGEAR folder.
[*]Plug in your WG111T.
[*]Go to Device Manager and find your WG111T in the list, Right Click and Update Driver.
[*]Browse to the DRIVERS folder on your desktop when it asks where to look for the driver and the WG111T will install. It should popup with a little message when it is completed but you will not be online yet.
[B]I dont know what you would do in Xp x64 system but I believe it has its own wireless manager like Vista and should be quite simalar.[/B]
[*]IN VISTA go to the Connect To button in your Start menu, It should be under Computer and Network, it should show your router along with a 5 bar network strength graphic.
[*]For me all I had to do was double click on the network and put in my WEP hex key and it conected.
[/LIST]
Gamertag: NeoNMD
Nov 04, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER
Configure router via ethernet cable in first instance. Then install adapter. May need to hange MTU for AOL as ISP.
Oct 08, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
