We have a peavey fire bass 700 and we were using it in an outside program. We plugged up a sunn bass cabinet with 2 15' wolfers then we plugged up an additional cabinet with 2 12" wolfers. Both cabinets were 4 ohm. The amp went out and we aren't getting any lights on the face of cabinet. We took it apart and tested the wires to see if we were getting power and there is power going into the copper coil but not coming out. We thought that it might have blown a fuse but the 2 fuses that we can see look ok. What do you think is wrong
  • 4,234 Answers
This amp is designed for a 4 ohm load. By connecting the two cabinets, you presented a 2 ohm load to the amp and overworked it. I suspect that the amp will now need repair. I don't know the particulars of your model, but if you have a way to check transistors, you may be able to repair this yourself. Let me know if you want to attempt this.
Dan
Posted on Sep 24, 2008
How do I open a 1210HS Peavey speaker cabinet?
With a screwdriver.
In some, you just pull out the Bass speaker, everything else is sealed, and get at the Xover from the hole....
Nov 22, 2017 | Peavey Music
I want to know where to buy a Peavy bass cabinet serial number 3E-01473871
Perhaps you needto ask about a model number rather than a serial number. It's doubtful you will be able to find the one specific cabinet with this serial number. Your only hope would be to contact Peavey directly to see if the owner registered the warranty.
Jul 02, 2015 | Bass Music
Trying to connect peavey tour 700 to a trace elliot 1518 bass enclosure. Plug the enclosure to the back of the amp. Then plugged my bass into the high gain. Turned it on and nothing happens.
Check continuity on all cables, try a different cabinet with the head and a different head with the cabinet and the bass with a different rig to see which part of the chain isn't working, make sure the volume controls are turned up on both the amp and bass. Once the problem is narrowed down it will be easier to advise you.
Oct 12, 2014 | Music
I have a peavey 700 tour series amp. When i turn it on the protect clip light comes on and there is no output to my speakers. Could you please help?
Are you an Electronics Technician? preferably with a good understanding of class H amplifiers and surface mount soldering skills. If not take it to the shop.
Dec 10, 2013 | Peavey Tour 700 Bass Guitar Amplifier Head
I use an SVT450H with the SVT410E and the SVT15E both 8 ohm Ampeg cabs. I have to have the main gain on 5 to 6 and the master volume on 7 to 8 and that is in smaller venues. I use a 1964 Fender Jazz Bass...
Check to see the phasing of the two cabinets and the cable. Take a 9 volt battery and touch it to the end of a cable that is plugged into the cabinet. The + of the battery has to be on the tip, and the - to the sleeve. See If the speakers move outward. Check each cabinet if they do then they ae in phase. Now try it with the second cable the results should be the same. If not and they move in the opposite direction then that cable is wired wrong. If one of the cabinets move in the opposite direction than the cabinet is wired wrong. You can also run one cabinet at a time if they sound louder by them selves that should also tell you that something is out of phase.
Jun 17, 2011 | Ampeg SVT 450H Classic Series Solid state...
Can you directly hook a sr16 to a peavey bass speaker cabinet using the output mono on the sr16 to send or retrn on the cabinet?
You can, however a bass speaker cabinet will NOT handle the higher pitch sounds needed for cymbals and snares, etc. You would connect it to the return AND doing so would DISABLE the other inputs of the bass speaker cabinet.
If you want both a guitar and drum machine into the cabinet, you need at least a small mixer or a speaker cabinet that can take two channels input simultaneously.
Plugging into the "return" of the cabinet DISCONNECTS the power amp from the preamp section in the cabinet.
Nov 09, 2009 | Alesis Sr 16 Stereo Drum Machine
Bass tone problem
Both of your problem amps were made in the '70's or earlier. It is entirely possible that the coupling capacitors are failing. This is an issue for a service center whether it is caps or something else, like failing tubes.
The good news is that installing metalized polypropelene capacitors will make those classic amps sound incredible.
Nov 04, 2008 | 3Com SuperStack II advanced RPS...
Bass amp settings
For rock and slapping you are going to want to set the Bass and Treble controls high and the Mids low. For music such as Jazz you are going to want more mids so that your sound will be fatter. If there is a button marked "Mid-Scoop" you'll want that on when slapping.
Nov 08, 2007 | Audio Players & Recorders
132 people viewed this question
 Grubhead
Grubhead
