Question about kawasaki Full Suspension Mountain Bike Men
Kawasaki KLX 400 dirt bike
I just replaced the magneto cover on my bike. I moved all the parts from the old cover into the new cover just like it was. After completing the job, I tried to start the bike and found it will not start. It turns over but doesn't start. Any suggestions?
Kyle
    New Friend:
  • 41 Answers
Hello, check to see if u have fire at the plug. If no fire, then check wires at the new cover
Posted on Nov 25, 2008
2004 kawasaki klx125 dirt bike. What's up on them know any place to get parts cheap cheap really need to get some bad but ******* money
Your local salvage yard or look i n the classifieds you'll find people selling their bikes for parts don't forget ebay. It's also a very lucrative business.
Apr 04, 2017 | 2004 kawasaki KLX 125 L
Ok I have a 2004 kawasaki klx125 dirt bike. It was ran on mixed fuel. Will this mess or blow or cease the bike if continued to run on this
Hi, James it won't hurt anything, probably smoke a lot and may oil foul a spark plug, why not just drain it and replace with straight gas if your that concerned for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2 Stroke Fuel in 4 Stroke Bike
What could happen if use 2 cycle fuel in 4 cycle engine
Kawasaki KLX125 2003 2006 Workshop Service Repair Manual Download Manuals... $10 cheap
OEM Parts for Kawasaki
Kawasaki KLX125 Owner Manual
How to replace rear wheel bearings on a kawasaki klx140 l
use a slide hammer with bearing attachment to pull out old bearings
and replace with new ones
Jul 22, 2014 | Pit Bike 125cc 4 Stroke Dirt Bike
Clogged fuel line
replace the fuel line , remove tank and remove fuel tap and clean out ! might be a good idear to strip the carb too ! sounds like the bike not used enough and the fuel gone off ! 6mths and fuel is off and only good for cleaning dirt off parts !! P....
Nov 21, 2013 | 1998 kawasaki KLX 300
KLX 110 not getting enough spark i think to burn the fuel
Hi, Jason and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a "LOAD" test if necessary, your battery may show 12.5 volts but have little or zero amps and needs to be replaced.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, stator, magneto, points/condenser ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. Fuel tank contaminated with ethanol sludge.
15. The gas cap is not venting properly or fuel tank venting system blocked.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
http://www.miniriders.com/ask-the-tech-masters-/33469-klx-110-wont-start.html
05 KLX 110 Wont Start
Kawasaki KLX110 Service Manual
Kawasaki KLX110 Owner Manual
Apr 06, 2017 | 2005 kawasaki KLX 110
My klx 400 stock carb would stop leaking gas through the over flow line. why?
check and clean the carb, there must be a dirt or an small object blocking the intake line of carb causing to malfunction the fuel floater. the floater acts like a control switch when the fuel reservoiris already full the floater floats causing to shut of the fuel.
May 02, 2011 | 2003 kawasaki KLX 400 SR
What battery do I need for kawasaki 400?
http://cgi.ebay.com/ebaymotors/YT7B-BS-Kawasaki-KLX400-KLX-400-DRZ-400-DRZ400-BATTERY-/170458253187 hope this helps battery is a 12v and number is YT7B-BS or YT7B-4 ebay price 24 dollars sterling be about 15 pound
Feb 13, 2011 | 2003 kawasaki KLX 400 R
No power at the coil
magneto is bad more than likely
May 22, 2009 | 2004 kawasaki KLX 400 SR
KLX 250 won't fire - new battery
-check the fuse right hand side below the fuel tank and seat, see if it is blown.
- Check to see if plug has spark, replace if necessary .
- Did you run the bike with a low battery before replacing it? could be that your stator is shot.
-Is bike trying to start but won't?
Mar 21, 2009 | 2007 kawasaki KLX 250
Kawasaki 400 KLX dirt bike
Hmmm. In the magneto is a whole bunch of copper wires. If one of these from the positinve charge is touching one from the negative it cang screw a whole bunch of things up.
Sep 25, 2008 | kawasaki Full Suspension Mountain Bike Men
kawasaki Full Suspension Mountain Bike Men Logo
226 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
