I can't seem to turn on my laptop (HP Pavilion dv6000). When I first attempted to turn on my laptop i saw a bit of smoke come out of the power connector spot. Now I don't think that is a good thing and when i checked the quick reference book the only thing that it talks about is low battery and just charging it in the right location. I'm just wondering if there is anything else i can do to fix this problem.
Your Pavilion DV6000 laptop is the key to your productivity, which is why it is essential that it turns on when you need it. The DV6000 is lighter than comparable models from other brands, and has a large, sharp display. While it has plenty of processing power, the DV6000 can have normal boot problems as well as problems caused by faulty battery packs that were installed in some units. Attempt to troubleshoot the laptop and find out if the laptop is eligible for a new battery pack.
1.Hard reset your laptop if there is no life at all. Unplug all peripheral devices and remove the battery. Unplug the AC cable and press and hold the power button for at least 15 seconds to drain all power. Reconnect the AC cable and hit the power button. 2.Verify that the battery pack is on the recall list if the laptop powers up without it. Fill out the form on the battery pack recall website (http://bpr.hpordercenter.com/hbpr/). You will have to input the serial number of the battery pack as well as a location to ship the replacement battery if you are eligible. 3.Hold the AC cable where it plugs into the laptop and wiggle it while hitting the power button one time. LEDs that come on and off intermittently indicate a faulty power cable. Order a replacement power cable through HP or a third-party vendor. 4.Write down any visual or audio error codes such as LEDs blinking or unusual beeping. The error sequence will be helpful when talking to an HP support person.
Remove the battery and the power plug, now replug in the power plug alone and attempt to boot. If the laptop starts then the issue is the battery. If not the laptop has failed and you'll need to contact HP for service or a local service tech if it's outside of warranty.
-Ravi Shanghavi, Ottawa
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Have you tried to boot the laptop with the power cable connected? Is the charging indicator on when you connect it to the adapter? If the charging indicator does not light up, check if your adapter output and try booting it with the power cable connected.
